查看: 17009|回复: 10
DMA+TIM +ADC采样只有第一次读出来数据
发表于 2015-12-29 10:52:52 | 显示全部楼层 |阅读模式
#include "./tim/bsp_general_tim_2_3_4_5.h"  //í¨óö¨ê±Æ÷
static void TIM2_Mode_Config(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseInitStructure;
  u16 TimerPeriod =  (SystemCoreClock / 90000 ) - 1;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
//        TIM_TimeBaseInitStructure.TIM_Period = TimerPeriod - 1;
//  TIM_TimeBaseInitStructure.TIM_Prescaler = 0;   //Timer clock = sysclock /(TIM_Prescaler+1) = 168M
        TIM_TimeBaseInitStructure.TIM_Prescaler = ((SystemCoreClock/2)/1000000)-1;   //Timer clock = sysclock /(TIM_Prescaler+1) = 168M
        TIM_TimeBaseInitStructure.TIM_Period = 1000000-1;    //Period = (TIM counter clock / TIM output clock) - 1 = 20K
  TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;  //?????
  TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1; //??????
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
        // Çå3y¼ÆêyÆ÷ÖD¶Ï±ê־λ
        TIM_ClearFlag(TIM2, TIM_FLAG_Update);
        // ¿aÆô¼ÆêyÆ÷ÖD¶Ï
        TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
        // ê1Äü¼ÆêyÆ÷
        TIM_Cmd(TIM2, ENABLE);
  * @brief  3õê¼»ˉ»ù±¾¶¨ê±Æ÷¶¨ê±£¬1ms2úéúò»′ÎÖD¶Ï
  * @param  ÎT
  * @retval ÎT
void TIMx_Configuration_2_3_4_5(void)
        TIM2_Mode_Config();
static void Rheostat_ADC_Mode_Config(void)
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  // ¿aÆôADCê±Öó
        RCC_APB2PeriphClockCmd(RHEOSTAT_ADC_CLK , ENABLE);
        // ------------------DMA Init ½á11ìå2Îêy 3õê¼»ˉ--------------------------
  // ADC1ê1óÃDMA2£¬êy¾Yá÷0£¬í¨μà0£¬Õa¸öêÇêÖ2á1춨ËàμÄ
  // ¿aÆôDMAê±Öó
  RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_DMA_CLK, ENABLE);
        // íaéè»ùÖ·Îa£oADC êy¾Y¼Ä′æÆ÷μØÖ·
        DMA_InitStructure.DMA_PeripheralBaseAddr = RHEOSTAT_ADC_DR_ADDR;
  // ′æ′¢Æ÷μØÖ·£¬êμ¼êéϾíêÇò»¸öÄú2¿SRAMμıäá¿
        DMA_InitStructure.DMA_Memory0BaseAddr = (u32)&ADC_ConvertedValue;
  // êy¾Y′«êä·½ÏòÎaíaéèμ½′æ′¢Æ÷
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        // »o3åÇø′óD¡Îa1£¬»o3åÇøμÄ′óD¡ó|¸Ãμèóú′æ′¢Æ÷μÄ′óD¡
        DMA_InitStructure.DMA_BufferSize = 1;
        // íaéè¼Ä′æÆ÷Ö»óDò»¸ö£¬μØÖ·2»óÃμYÔö
  // ′æ′¢Æ÷μØÖ·1춨
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  // // íaéèêy¾Y′óD¡Îa°ë×Ö£¬¼′ὸö×Ö½ú
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  //        ′æ′¢Æ÷êy¾Y′óD¡ò2Îa°ë×Ö£¬¸úíaéèêy¾Y′óD¡Ïàí¬
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        // Ñ-»·′«êäÄ£ê½
  // DMA ′«êäí¨μàóÅÏ輶Îa¸ß£¬μ±ê1óÃò»¸öDMAí¨μàê±£¬óÅÏ輶éèÖÃ2»ó°Ïì
  // ½ûÖ1DMA FIFO        £¬ê1óÃÖ±á¬Ä£ê½
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  // FIFO ′óD¡£¬FIFOģ꽽ûÖ1ê±£¬Õa¸ö2»óÃÅäÖà
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        // Ñ¡Ôñ DMA í¨μ࣬í¨μà′æÔúóúá÷ÖD
  DMA_InitStructure.DMA_Channel = RHEOSTAT_ADC_DMA_CHANNEL;
  //3õê¼»ˉDMAá÷£¬á÷Ïàμ±óúò»¸ö′óμÄ1üμ࣬1üμààïÃæóDoü¶àí¨μà
        DMA_Init(RHEOSTAT_ADC_DMA_STREAM, &DMA_InitStructure);
        // ê1ÄüDMAá÷
  DMA_Cmd(RHEOSTAT_ADC_DMA_STREAM, ENABLE);
  // -------------------ADC Common ½á11ìå 2Îêy 3õê¼»ˉ------------------------
        // ¶àá¢ADCÄ£ê½
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  // ê±ÖóÎafpclk x·ÖÆμ
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  // ½ûÖ1DMAÖ±½ó·ÃÎêģ꽠
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  // 2éÑùê±¼ä¼ä¸ô
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  // -------------------ADC Init ½á11ìå 2Îêy 3õê¼»ˉ--------------------------
  // ADC ·Ö±æÂê
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  // ½ûÖ1é¨Ãèģ꽣¬¶àí¨μà2é¼ˉ2ÅDèòa
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
          // á¬Dø×a»»
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; /////////////////μ¥′Î×a»»
        //ê1óÃèí¼t′¥·¢£¬ía2¿′¥·¢2»óÃÅäÖã¬×¢êíμô¼′¿é
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO;      //  1ê1óö¨Æ÷′¥·¢Ä£ê½
  //½ûÖ1ía2¿±ßÑØ′¥·¢
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;  //   2ê1óö¨ê±Æ÷éÏéyÑؽøDD′¥·¢
//  // á¬Dø×a»»
//  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; /////////////////μ¥′Î×a»»
//  //½ûÖ1ía2¿±ßÑØ′¥·¢
//  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;  /////////////////////////ía2¿éÏéyÑØ′¥·¢2éÑù
//  //ê1óÃèí¼t′¥·¢£¬ía2¿′¥·¢2»óÃÅäÖã¬×¢êíμô¼′¿é
//  //ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;      /////////////////////////
  //êy¾Yóò¶ÔÆë
  //×a»»í¨μà 1¸ö
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(RHEOSTAT_ADC, &ADC_InitStructure);
  // ÅäÖà ADC í¨μà×a»»Ë3DòÎa1£¬μúò»¸ö×a»»£¬2éÑùê±¼äÎa3¸öê±ÖóÖüÆú
  ADC_RegularChannelConfig(RHEOSTAT_ADC, RHEOSTAT_ADC_CHANNEL, 1, ADC_SampleTime_3Cycles);
  // ê1ÄüDMAÇëÇó after last transfer (Single-ADC mode)
  ADC_DMARequestAfterLastTransferCmd(RHEOSTAT_ADC, ENABLE);
  // ê1ÄüADC DMA
  ADC_DMACmd(RHEOSTAT_ADC, ENABLE);
  // ê1ÄüADC
  ADC_Cmd(RHEOSTAT_ADC, ENABLE);
  //¿aê¼adc×a»»£¬èí¼t′¥·¢
  ADC_SoftwareStartConv(RHEOSTAT_ADC);
  * @brief  ADC13õê¼»ˉ
  * @param  ÎT
  * @retval ÎT
void Rheostat_Init(void)
        Rheostat_ADC_GPIO_Config();
        Rheostat_ADC_Mode_Config();
 楼主| 发表于 2015-12-29 13:23:14 | 显示全部楼层
搞好了,完成   定时器产生时种,每隔一定时间去让ADC工作,然后经DMA传输!有谁需要留言好了
发表于 2015-12-29 18:47:48 | 显示全部楼层
设置定时触发
发表于 2016-1-4 15:31:17 | 显示全部楼层
我需要,正在研究DMA,谢谢! 邮箱 seesky90@126.com
发表于 2016-4-25 11:17:32 | 显示全部楼层
511326260@qq.com
谢谢楼主
发表于 2018-3-2 20:24:42 | 显示全部楼层
我近来也在搞,搞了很久还是有点问题,感谢分享,173919225@163.com
发表于 2018-5-29 10:22:48 | 显示全部楼层
需要,辛苦啦,求回复209053144@qq.com
发表于 2019-3-21 22:19:42 | 显示全部楼层
大神辛苦了,急需,谢谢!1061091328@qq.com
发表于 2019-3-29 17:26:44 | 显示全部楼层
谢谢大神,辛苦了,如果还方便的话,麻烦请您再发我一份:546144795@qq.com,谢谢!
发表于 2019-8-8 11:21:46 | 显示全部楼层
大神  需要一份  1782050342@qq。com
发表于 2020-5-21 11:48:29 | 显示全部楼层
感谢大神 262408369@qq.com
GMT+8, 2024-4-28 08:37 , Processed in 0.046945 second(s), 24 queries , Gzip On.
