查看: 8746|回复: 2
关于串口接收中断
发表于 2016-3-31 23:43:50 | 显示全部楼层 |阅读模式
程序设定的是串口1 接收中断 然后用指定的串口命令(16进制代码)控制led
在调试的时候串口助手怎么发送都没用回应,中断函数里面加入的测试代码也没有效果(接收以后触发中断,点亮led,然后返回接收的值)
下面附上源代码(固件库版本:3.5,软件:keil)
#include <stm32f10x.h>
#include <stm32f10x_gpio.h>
#include <stm32f10x_usart.h>
#include <misc.h>
void NVIC_setting(void);                //中断设置
void GPIO_setting(void);                //GPIO设置
void USART_setting(void);                //USART设置
/*主函数*/
                NVIC_setting();
                GPIO_setting();
                USART_setting();
        //        GPIO_SetBits(GPIOB , GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_5);                //关闭LED
/*中断函数*/
void USART_IRQHandler(void)                                //USART中断子函数
                if(USART_GetITStatus(USART1, USART_IT_RXNE)!= RESET)                //如果有接收
                                USART_ClearFlag(USART1,USART_FLAG_RXNE);
                                USART_ClearITPendingBit(USART1,  USART_IT_RXNE);                //清除中断标志位
                /*测试代码*/
                                GPIO_ResetBits(GPIOB , GPIO_Pin_1);                        //如果有接收就点亮led
                                USART_SendData(USART1 , USART_ReceiveData(USART1) );
/*中断设置*/
void NVIC_setting(void)                             //中断设置
        NVIC_InitTypeDef NVIC_InitStruct;             //定义中断变量
        /*串口1中断*/
        NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn ;
        NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;                        //中断响应优先级0
        NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;        //中断占先优先级0
        NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;                      //开中断
        NVIC_Init(&NVIC_InitStruct);
/*GPIO设置*/
        GPIO_InitTypeDef GPIO_InitStruct;        //定义GPIO宏定义
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);                //开APB2串口1,GPIOA,AFIO时钟
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_9        ;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;                                                        //复用推挽输出
        GPIO_Init(GPIOA, &GPIO_InitStruct);        //设置GPIOA_9
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10        ;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;                                //悬空
        GPIO_Init(GPIOA, &GPIO_InitStruct);        //设置GPIOA_10
                                                /****GPIOB设置,用于LED输出****/
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB , ENABLE);                        //开启GPIOB时钟
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_5 ;                //选定GPIOB_PIN_0,1,5
        /*pin0:红灯,pin1:绿灯,pin5:蓝灯*/
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP        ;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz ;
        GPIO_Init(GPIOB, &GPIO_InitStruct);        //设置GPIOb
/*串口设置*/
        USART_InitTypeDef USART_InitStruct;
        USART_InitStruct.USART_BaudRate = 9600;
        USART_InitStruct.USART_StopBits = USART_StopBits_1;
        USART_InitStruct.USART_WordLength = USART_WordLength_8b;
        USART_InitStruct.USART_Parity = USART_Parity_No;
        USART_InitStruct.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
        USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_Init(USART1 , &USART_InitStruct);                //设置串口1
        USART_Cmd(USART1 , ENABLE);        //开启串口1
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);                                                //接收中断
发表于 2016-4-1 08:32:40 | 显示全部楼层
发个例程你参考下,也是串口1接收中断,也是通过串口调试助手发送命令控制开发板的LED灯
USART1—USART1指令控制RGB彩灯.zip (344.49 KB, 下载次数: 14)
 楼主| 发表于 2016-4-2 11:37:22 | 显示全部楼层
好的 谢谢啦 昨天调试下 发现是串口命令最后没有加上0x0d 0x0a触发接收中断
GMT+8, 2024-5-9 00:50 , Processed in 0.030334 second(s), 27 queries , Gzip On.
