查看: 11955|回复: 6
编译OV5640实验中的WiFi传输JPEG例程出错
发表于 2016-11-24 18:53:38 | 显示全部楼层 |阅读模式
*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'E:\ARM-MDK\ARM\ARMCC\Bin'
Build target 'MICO-Fire-OV5640'
linking...
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6654E: Rejected Local symbol .text7 referred to from non group member internal.o(.iar.stackusage)
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #25 '$t' in .bss(mxchipWNET.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #26 '$t' in .bss(mxchipWNET.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #27 '$t' in .bss(mxchipWNET.o:9) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #28 '$t' in .bss(mxchipWNET.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #172 '$t' in .bss(mxchipWNET.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #173 '$t' in .bss(mxchipWNET.o:13) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #198 '$t' in .bss(mxchipWNET.o:14) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #233 '$t' in .bss(mxchipWNET.o:15) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #213 '$t' in .bss(ssl.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #214 '$t' in .bss(ssl.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #304 '$t' in .bss(ssl.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #305 '$t' in .bss(ssl.o:11) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #306 '$t' in .bss(ssl.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #148 '$t' in .bss(tasks.o:32) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #316 '$t' in .bss(wifimgr.o:138) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #11 '$t' in .bss(dnsclient.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #12 '$t' in .bss(dnsclient.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #36 '$t' in .bss(ostimers.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #15 '$t' in .bss(udp.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #42 '$t' in .bss(wifi.o:16) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #39 '$t' in .bss(wps_host.o:7) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #40 '$t' in .bss(wps_host.o:8) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #41 '$t' in .bss(wps_host.o:9) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #42 '$t' in .bss(wps_host.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #43 '$t' in .bss(wps_host.o:11) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #44 '$t' in .bss(wps_host.o:12) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #45 '$t' in .bss(wps_host.o:13) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #46 '$t' in .bss(wps_host.o:14) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #47 '$t' in .bss(wps_host.o:15) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #48 '$t' in .bss(wps_host.o:16) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #49 '$t' in .bss(wps_host.o:17) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #50 '$t' in .bss(wps_host.o:18) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #51 '$t' in .bss(wps_host.o:19) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #52 '$t' in .bss(wps_host.o:20) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #53 '$t' in .bss(wps_host.o:21) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #54 '$t' in .bss(wps_host.o:22) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #55 '$t' in .bss(wps_host.o:23) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #56 '$t' in .bss(wps_host.o:24) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #14 '$t' in .bss(wwd_internal.o:9) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #50 '$t' in .bss(wwd_internal.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #120 '$t' in .bss(wwd_wifi.o:55) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Warning: L6170W: Mapping symbol #16 '$t' in .bss(netif.o:10) identifies code, but is in a section not marked as executable.
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wps_host.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches tasks.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches dnsclient.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches mxchipWNET.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wifi.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wifimgr.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches ostimers.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches udp.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_internal.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches wwd_wifi.o(.bss).
..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf: Error: L6405E: No .ANY selector matches netif.o(.bss).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 43 warning and 37 error messages.
"..\..\..\..\Build\demo\MICO-Fire_F429\obj_RVMDK\mdk_demo.axf" - 37 Error(s), 43 Warning(s).
Target not created.
Build Time Elapsed:  00:00:04
请问这个怎么解决啊,例程中的说明文档没说有这种错误啊
发表于 2016-11-24 19:15:50 | 显示全部楼层
要用工程目录下说明文档里指定的编译器版本
 楼主| 发表于 2016-11-30 09:29:32 | 显示全部楼层
我的ARM  Compiler 是'V5.05 update 2 (build 169),必须是V5.05啊。
MDK版本是5.17,这个是去官网找之前的版本是吧?
发表于 2016-11-30 11:39:30 | 显示全部楼层
MDK版本是5.17,这个是去官网找之 ...
编译器是5.05那可以了
 楼主| 发表于 2016-11-30 20:45:11 | 显示全部楼层
flyleaf 发表于 2016-11-30 11:39
编译器是5.05那可以了
那我怎么出现上面的问题啊。我的就是5.05
发表于 2016-12-5 09:20:11 | 显示全部楼层
搞不懂,之前编译这个程序出现这些错误提示都是编译器版本问题,你再确认一下
发表于 2019-3-8 22:04:29 | 显示全部楼层
同问啊 楼主后面解决了嘛
GMT+8, 2024-5-4 13:44 , Processed in 0.031803 second(s), 23 queries , Gzip On.
