查看: 4687|回复: 1
[ucos] 指南者上移植ucos-ii(注意是ucos-ii)同时移植STemwin,但在GUI_Delay()卡主了,怎...
发表于 2017-4-4 17:58:12 | 显示全部楼层 |阅读模式
*                                                uC/GUI
*                        Universal graphic software for embedded applications
*                       (c) Copyright 2002, Micrium Inc., Weston, FL
*                       (c) Copyright 2002, SEGGER Microcontroller Systeme GmbH
*              ?C/GUI is protected by international copyright laws. Knowledge of the
*              source code may not be used to write a similar product. This file may
*              only be used in accordance with a license and should not be redistributed
*              in any way. We appreciate your understanding and fairness.
---Author-Explanation
* 1.00.00 020519 JJL    First release of uC/GUI to uC/OS-II interface
* Known problems or limitations with current version
*    None.
* Open issues
*    None
#include <includes.h>
#include "GUI_Private.H"
#include "stdio.H"
*                                         GLOBAL VARIABLES
static  OS_EVENT  *DispSem;
static  OS_EVENT  *EventMbox;
static  OS_EVENT  *KeySem;
static  int        KeyPressed;
static  char       KeyIsInited;
*                                        TIMING FUNCTIONS
* Notes: Some timing dependent routines of uC/GUI require a GetTime and delay funtion.
*        Default time unit (tick), normally is 1 ms.
int GUI_X_GetTime(void)
   return ((int)OSTimeGet());
void GUI_X_Delay(int period)
  INT32U  ticks;
  ticks=(period*1000)/OS_TICKS_PER_SEC;
  OSTimeDly((INT16U)ticks);
*                                          GUI_X_ExecIdle()
void GUI_X_ExecIdle(void)
// OS_X_Delay(1);
  OSTimeDly(1);   //把1改为50也不行,ucos的服务全开了
*                                    MULTITASKING INTERFACE FUNCTIONS
* Note(1): 1) The following routines are required only if uC/GUI is used in a true multi task environment,
*             which means you have more than one thread using the uC/GUI API.  In this case the #define
*             GUI_OS 1   needs to be in GUIConf.h
void GUI_X_InitOS (void)
    DispSem = OSSemCreate(1);           //??????????????????
    EventMbox = OSMboxCreate((void *)0);//???????????
void GUI_X_Lock(void)
  INT8U err;
  OSSemPend(DispSem,0,&err);
void GUI_X_Unlock(void)
  OSSemPost(DispSem);
U32 GUI_X_GetTaskId(void)
  return ((U32)(OSTCBCur->OSTCBPrio));
*                                        GUI_X_WaitEvent()
*                                        GUI_X_SignalEvent()
void GUI_X_WaitEvent(void)
   INT8U err;
   (void)OSMboxPend(EventMbox,0,&err);
void GUI_X_SignalEvent(void)
  (void)OSMboxPost(EventMbox,(void *)1);
*                                      KEYBOARD INTERFACE FUNCTIONS
* Purpose: The keyboard routines are required only by some widgets.
*          If widgets are not used, they may be eliminated.
* Note(s): If uC/OS-II is used, characters typed into the log window will be placedin the keyboard buffer.
*          This is a neat feature which allows you to operate your target system without having to use or
*          even to have a keyboard connected to it. (useful for demos !)
static void CheckInit(void)
  if(KeyIsInited==DEF_FALSE)
      KeyIsInited = DEF_TRUE;
      GUI_X_Init();
/*??GUI_Init()????,??????????ЩGUI???????????????,??????????????????.????????????,???????*/
void GUI_X_Init(void)
  KeySem = OSSemCreate(0);
int GUI_X_GetKey(void)
    int r;
    r = KeyPressed;
    CheckInit();
    KeyPressed = 0;
    return (r);
int GUI_X_WaitKey(void)
    int  r;
    INT8U  err;
    CheckInit();
    if(KeyPressed==0)
        OSSemPend(KeySem,0,&err); //????????
    r= KeyPressed;
    KeyPressed = 0;
    return (r);
void GUI_X_StoreKey(int k)
    KeyPressed = k;
    OSSemPost(KeySem); //????????
void GUI_X_Log     (const char *s) { GUI_USE_PARA(s); }
void GUI_X_Warn    (const char *s) { GUI_USE_PARA(s); }
void GUI_X_ErrorOut(const char *s) { GUI_USE_PARA(s); }
/********************end****************************/
static  void  App_TasKDisplay (void  *p_arg)         //5
    (void)p_arg;
   LCD_BK_EN;          //开液晶屏背光
  CreateWindow_M_S();
  macLED2_ON();
  GUI_Delay(20);       //就是在这里被卡主了2灯亮,1灯不亮
    macLED1_ON();
    while (DEF_TRUE) {
   OSTimeDlyHMSM(0, 0, 10, 0);
有哪位好心人解答下。。
发表于 2017-4-5 08:48:47 | 显示全部楼层
参考一下我们的综合例程来移植
GMT+8, 2024-5-27 09:01 , Processed in 0.027647 second(s), 24 queries , Gzip On.
