查看: 16141|回复: 5
STM32F429 硬件IIC与BMP180通信卡在EV6
发表于 2017-7-10 21:43:19 | 显示全部楼层 |阅读模式
1火花
如题
  1. #include "I2C.h"
  2. static void I2C_GPIO_Config(void){
  3.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
  4.
  5.         GPIO_InitTypeDef GPIO_InitStruct;
  6.
  7.         GPIO_PinAFConfig(I2C_PORT,I2C_SCL_SOURCE,GPIO_AF_I2C1);
  8.         GPIO_PinAFConfig(I2C_PORT,I2C_SDA_SOURCE,GPIO_AF_I2C1);
  9.
  10.         GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
  11.         GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
  12.         GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
  13.         GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
  14.
  15.         GPIO_InitStruct.GPIO_Pin = I2C_SCL | I2C_SDA;
  16.
  17.         GPIO_Init(I2C_PORT,&GPIO_InitStruct);
  18. }
  19. static void I2C_Mode_Config(void){
  20.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
  21.
  22.         I2C_InitTypeDef I2C_IbitStruct;
  23.
  24.         I2C_DeInit(I2C_BASIC);
  25.         I2C_IbitStruct.I2C_ClockSpeed = I2C_SPEED;
  26.         I2C_IbitStruct.I2C_Mode = I2C_Mode_I2C;
  27.         I2C_IbitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
  28.         I2C_IbitStruct.I2C_OwnAddress1 = OWN_ADRESS;
  29.         I2C_IbitStruct.I2C_Ack = I2C_Ack_Enable;
  30.         I2C_IbitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  31.
  32.         I2C_Init(I2C_BASIC,&I2C_IbitStruct);
  33.
  34.         I2C_Cmd(I2C1,ENABLE);
  35.
  36.          I2C_AcknowledgeConfig(I2C_BASIC, ENABLE);
  37. }
  38. void I2C_Config(void){
  39.         I2C_GPIO_Config();
  40.         I2C_Mode_Config();
  41. }
  1. #ifndef _I2C_H_
  2. #define _I2C_H_
  3. #include "stm32f4xx.h"
  4. #define I2C_PORT                        GPIOB
  5. #define I2C_BASIC                        I2C1
  6. #define I2C_SCL                                GPIO_Pin_6
  7. #define I2C_SCL_SOURCE                GPIO_PinSource6
  8. #define I2C_SDA                                GPIO_Pin_7
  9. #define I2C_SDA_SOURCE                GPIO_PinSource7
  10. #define I2C_SPEED                        10000
  11. #define OWN_ADRESS                        0xEE
  12. void I2C_Config(void);
  13. #endif /*_I2C_H_*/
  1. #include "BMP180.h"
  2. static short BMP180_Read_Data(unsigned char ADDR){
  3.         unsigned char msb,lsb;
  4.         short Data;
  5.
  6.         while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
  7.
  8.         I2C_AcknowledgeConfig(BMP180_I2C, ENABLE);
  9.
  10.         I2C_GenerateSTART(BMP180_I2C,ENABLE);
  11.
  12.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_MODE_SELECT)){
  13.         }
  14.
  15.         I2C_Send7bitAddress(BMP180_I2C,BMP180_Write_ADDR,I2C_Direction_Transmitter);
  16.
  17.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)){
  18.         }
  19.
  20.         I2C_SendData(BMP180_I2C,ADDR);
  21.
  22.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_BYTE_TRANSMITTED)){
  23.         }
  24.
  25.         I2C_GenerateSTART(BMP180_I2C,ENABLE);
  26.
  27.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_MODE_SELECT)){
  28.         }
  29.
  30.         I2C_Send7bitAddress(BMP180_I2C,BMP180_Read_ADDR,I2C_Direction_Transmitter);
  31.
  32.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)){
  33.         }
  34.
  35.         msb = I2C_ReceiveData(BMP180_I2C);
  36.
  37.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_BYTE_RECEIVED)){
  38.         }
  39.
  40.         I2C_NACKPositionConfig(BMP180_I2C,I2C_NACKPosition_Next);
  41.
  42.         lsb = I2C_ReceiveData(BMP180_I2C);
  43.
  44.         while(!I2C_CheckEvent(BMP180_I2C,I2C_EVENT_MASTER_BYTE_RECEIVED)){
  45.         }
  46.
  47.         I2C_NACKPositionConfig(BMP180_I2C,I2C_NACKPosition_Current);
  48.
  49.
  50.         Data  = (msb << 8);
  51.         Data |= lsb;
  52.         return Data;
  53. }
  1. #include "stm32f4xx.h"
  2. #include "I2C.h"
  3.                 /*íaéèoê*/
  4. #define BMP180_I2C                                                I2C1
  5.
  6.                 /*BMP80μ&#216;&#214;·*/
  7. #define BMP180_Write_ADDR                                0xEE
  8. #define BMP180_Read_ADDR                                0xEF
发表于 2017-7-11 08:50:36 | 显示全部楼层
卡的话就直接改用软件I2C
 楼主| 发表于 2017-7-11 12:20:06 | 显示全部楼层
flyleaf 发表于 2017-7-11 08:50
卡的话就直接改用软件I2C
硬件没有办法解决吗
发表于 2017-10-17 19:57:31 | 显示全部楼层
卡的话就直接改用软件I2C
请问429硬件IIC也有问题吗
发表于 2017-10-18 09:15:56 | 显示全部楼层
Demonzjs 发表于 2017-10-17 19:57
请问429硬件IIC也有问题吗
都一样
发表于 2017-10-18 09:16:32 | 显示全部楼层
好的  谢谢
GMT+8, 2024-6-5 23:38 , Processed in 0.035949 second(s), 23 queries , Gzip On.
