查看: 6430|回复: 1
只能读取加速度、三轴、温度数据寄存器一次,之后都读不到??
发表于 2017-8-26 16:11:09 | 显示全部楼层 |阅读模式
只能读取一次数据寄存器
u8
u8g_i2c_read_buf( u8 u8t_i2c_slaveaddr, u8 u8t_reg_addr, u8 *u8t_buf, u8 u8t_buf_len )
        u8 u8t_ret = 0;
        u8 i = 0;
        /*------------------------- send read register address -------------------------*/
        /* wait i2c idle */
        while( I2C_GetFlagStatus( I2C1, I2C_FLAG_BUSY ) == SET );
        /* start signal */
        I2C_GenerateSTART( I2C1, ENABLE );
        /* check EV5 , read register SR1->clear EV5 */
        while( I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_MODE_SELECT ) == ERROR );
        /* send slave address */
        I2C_Send7bitAddress( I2C1, (u8t_i2c_slaveaddr << 1), I2C_Direction_Transmitter );
        /* check EV6 , read register SR1 and SR2->clear EV6 */
        while( I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED ) == ERROR );
        /* check EV8_2 , read register SR1 and SR2->clear EV8_2 */
        //while( I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED ) == ERROR );
        /* check EV8 , read register SR1 and SR2->clear EV8 */
        //while( I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTING ) == ERROR );
        /* send register address */
        I2C_SendData( I2C1, u8t_reg_addr );
        /*----------------------------- read register data -----------------------------*/
        /* start signal */
        I2C_Send7bitAddress( I2C1, (u8t_i2c_slaveaddr << 1), I2C_Direction_Receiver );
        while( I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED ) == ERROR );
        if ( u8t_buf_len == 1 )
                /* if external process */
        }else
                for( i=0; i<(u8t_buf_len-2); i++ )
                        /* check EV7 */
                        while( I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED ) == ERROR );                   //第2次,卡死在这
                        u8t_buf = I2C_ReceiveData( I2C1 );
                /* check EV7 */
        /* Disable Acknowledgment */
        I2C_AcknowledgeConfig( I2C1, DISABLE );
        /* stop signal */
        I2C_GenerateSTOP( I2C1, ENABLE );
        /* check EV7 */
        return u8t_ret;
另外一个问题,温度的解析不太对
代码:
        u8  u8t_mpu6050_buf[14];
        /* Temperature in degrees C =  (TEMP_OUT_Register_Value as a signed quantity)/340 + 36.53  */
        f32g_mpu6050_temp = (f32)( ( (u16)u8t_mpu6050_buf[6] << 8) | (u16)u8t_mpu6050_buf[7] );
        f32g_mpu6050_temp = ( f32g_mpu6050_temp/340.0) + 36.53 ;
现象: 764F975653FB46F599DD2D87593C504F.jpg
发表于 2017-8-26 18:32:00 | 显示全部楼层
有例程直接参考就好啦
GMT+8, 2024-5-16 12:25 , Processed in 0.078859 second(s), 26 queries , Gzip On.
