查看: 8665|回复: 1
2-FatFs文件系统常用函数测试___例程编译出错
发表于 2017-9-26 20:10:45 | 显示全部楼层 |阅读模式
错误的地方为:        va_start(arp, fmt);
                   p = va_arg(arp, TCHAR*);
                  putc_bfd(&pb, (TCHAR)va_arg(arp, int)); continue;
                v = (f & 4) ? (DWORD)va_arg(arp, long) : ((d == 'D') ? (DWORD)(long)va_arg(arp, int) : (DWORD)va_arg(arp, unsigned int));
错误报表:
*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'D:\keil5\ARM\ARMCC\Bin'
Build target 'fatfs'
compiling ff.c...
..\..\User\FATFS\ff.c(4596): error:  #928: incorrect use of va_start
a_start(arp, fmt);
..\..\User\FATFS\ff.c(4596): error:  #253: expected a ","
a_start(arp, fmt);
..\..\User\FATFS\ff.c(4596): error:  #29: expected an expression
a_start(arp, fmt);
..\..\User\FATFS\ff.c(4626): error:  #929: incorrect use of va_arg
                        p =
a_arg(arp, TCHAR*);
..\..\User\FATFS\ff.c(4635): error:  #929: incorrect use of va_arg
..\..\User\FATFS\ff.c(4650): error:  #929: incorrect use of va_arg
..\..\User\FATFS\ff.c: 0 warnings, 8 errors
"..\..\Output\Template.axf" - 8 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:02
发表于 2017-9-27 09:09:15 | 显示全部楼层
测试了没有问题,你重新到网盘里下载一下
GMT+8, 2024-5-22 22:02 , Processed in 0.048167 second(s), 24 queries , Gzip On.
