查看: 6777|回复: 2
界面不能刷新
发表于 2017-12-27 10:44:35 | 显示全部楼层 |阅读模式
下面的程序的目的是500ms改变一次对话框的背景色,但是不能够实现该功能,哪位大神能帮我看看这是怎么回事
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
#include        "BUTTON.h"
#include "CHECKBOX.h"
#include "EDIT.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include "MULTIEDIT.h"
#include "RADIO.h"
#include "SLIDER.h"
#include "TEXT.h"
#include "PROGBAR.h"
#include "SCROLLBAR.h"
#include "LISTVIEW.h"
#define  WM_Update WM_USER+1
GUI_COLOR _acColor[3] = {GUI_WHITE,GUI_RED,GUI_YELLOW};
static char ucBackColor;
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
        { FRAMEWIN_CreateIndirect, "armfly", 0,      50,  60, 200, 120, FRAMEWIN_CF_MOVEABLE },
        { BUTTON_CreateIndirect,   "Button0",   GUI_ID_BUTTON0,   100,  10,  80,  80 },
        { BUTTON_CreateIndirect,   "Button1",   GUI_ID_BUTTON1,   10,  10,  60,  20  }
static void PaintDialog(WM_MESSAGE* pMsg)
        WM_HWIN hWin = pMsg->hWin;
        GUI_SetBkColor(_acColor[ucBackColor]);
        GUI_Clear();
static void InitDialog(WM_MESSAGE* pMsg)
        FRAMEWIN_SetFont(hWin,&GUI_Font24B_ASCII); //设置框架窗口字体
        FRAMEWIN_SetTextAlign(hWin,GUI_TA_HCENTER|GUI_TA_VCENTER);
        FRAMEWIN_SetText(hWin,"armfly");  //设置标题
        hWin = WM_GetDialogItem(hWin,GUI_ID_BUTTON0); //获取BUtton的句柄
        BUTTON_SetFont(hWin,&GUI_Font24B_ASCII);//设置Button的字体
        BUTTON_SetText(hWin,"armfly");//设置button的名称
        ucBackColor = 0;
static void _cbCallback(WM_MESSAGE* pMsg)
        int Id;
        int NCode;
        GUI_HWIN hWin= pMsg->hWin;
        switch(pMsg->MsgId)
        case WM_PAINT:
                PaintDialog(pMsg);
                break;
        case  WM_Update:
                ucBackColor++;
                if (ucBackColor==3)
                        ucBackColor = 0;
                WM_InvalidateWindow(pMsg->hWin);
                break;
        case WM_INIT_DIALOG:
                InitDialog(pMsg);
                break;
        case WM_KEY:
                switch(((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                        GUI_EndDialog(pMsg->hWin,1);
                        break;
                case  GUI_KEY_ENTER:
                        GUI_EndDialog(pMsg->hWin,0);
                        break;
                break;
        case WM_NOTIFY_PARENT:
                Id = WM_GetId(pMsg->hWinSrc);
                NCode = pMsg->Data.v;
                switch(Id)
                case GUI_ID_BUTTON0:
                        switch(NCode)
                        case WM_NOTIFICATION_CLICKED:
                                /*ucBackColor++;
                                if (ucBackColor == 3)
                                        ucBackColor = 0;
                                WM_InvalidateWindow(hWin);*/
                                break;
                        case WM_NOTIFICATION_RELEASED:
                                break;
                        case WM_NOTIFICATION_MOVED_OUT:
                                break;
                        break;
                case GUI_ID_BUTTON1:
                        switch(NCode)
                                /*ucBackColor--;
                                if (ucBackColor < 0)
                                        ucBackColor = 2;
                                break;
                                break;
                                break;
                        break;
                break;
        default:
                WM_DefaultProc(pMsg);
static void _cbDialog(WM_MESSAGE*pMsg)
        WM_HWIN hItem;
        int NCode;
        int Id;
        switch (pMsg->MsgId)
                hItem = pMsg->hWin;
                FRAMEWIN_SetFont(hItem,&GUI_Font24B_ASCII); //设置框架窗口字体
                FRAMEWIN_SetTextAlign(hItem,GUI_TA_HCENTER|GUI_TA_VCENTER);
                FRAMEWIN_SetText(hItem,"armfly");  //设置标题
                hItem = WM_GetDialogItem(pMsg->hWin,GUI_ID_BUTTON0); //获取BUtton的句柄
                BUTTON_SetFont(hItem,&GUI_Font24B_ASCII);//设置Button的字体
                BUTTON_SetText(hItem,"armfly");//设置button的名称
                ucBackColor =0;
                break;
        case WM_PAINT:
                GUI_Clear();
                break;
        case WM_Update:
                ucBackColor++;
                        ucBackColor = 0;
                break;
                switch(Id)
                        switch(NCode)
                                break;
                                break;
                                break;
                        break;
                        switch(NCode)
                                break;
                                break;
                                break;
                        break;
                break;
        default:
                break;
WM_HWIN CreateFramewin(void)
        WM_HWIN hWin;
        hWin = GUI_CreateDialogBox(_aDialogCreate,GUI_COUNTOF(_aDialogCreate),_cbDialog,WM_HBKWIN,0,0);
        return hWin;
void MainTask(void)
        GUI_HWIN hDlg;
        GUI_Init();
        //WM_SetDesktopColor(GUI_BLUE); //刷新背景
        //WM_SetCreateFlags(WM_CF_MEMDEV);
//PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
        //FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX); //为什么添加该句就可以发送Paint消息
//BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
//CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
//        hDlg = GUI_ExecDialogBox(_aDialogCreate,GUI_COUNTOF(_aDialogCreate),&_cbCallback,0,0,0);
hDlg = GUI_CreateDialogBox(_aDialogCreate,GUI_COUNTOF(_aDialogCreate),&_cbCallback,0,0,0);
        //GUI_Delay(1000);
        while (1)
                WM_SendMessageNoPara(WM_GetClientWindow(hDlg),WM_Update);
                GUI_Delay(500);
                GUI_Exec();
        WM_HWIN hDlg;
        GUI_Init();
        hDlg = CreateFramewin();
        while (1)
                WM_SendMessageNoPara(hDlg,WM_Update);
                GUI_Delay(500);
发表于 2017-12-27 11:40:02 | 显示全部楼层
emwin有个函数强制刷新的,要调用一下
 楼主| 发表于 2017-12-27 14:35:40 | 显示全部楼层
是gui_exec吗还是  添加在哪个地方, 为什么我这样写就可以
GUI_Init();
还有个问题就是,在WM_UPDATE消息中已经有WM_InvalidateWindow(pMsg->hWin);使窗口无效,wm去执行wm_paint消息 这样就实现了对话框背景色的改变  但是实际上没有执行重绘操作,这怎么解释
GMT+8, 2024-5-17 14:16 , Processed in 0.044451 second(s), 24 queries , Gzip On.
