查看: 11416|回复: 3
STM32F205RE SPI DMA 发送不成功
发表于 2018-1-10 14:15:08 | 显示全部楼层 |阅读模式
我使用STM32F205 做SPI DMA 发送数据,总是发送不成功,请大家帮我看看是哪里出问题了,谢谢 !
  1. GPIO_InitTypeDef GPIO_InitStructure;
  2.         SPI_InitTypeDef  SPI_InitStructure;
  3.         DMA_InitTypeDef       DMA_InitStructure;
  4.     //int ii =0;
  5.         /*!< Enable SPI2 clocks */
  6.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
  7.         /*!< Enable GPIO clocks */
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  9.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  10.         /*!< Connect SPI pins to AF5 */
  11.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_SPI2);
  12.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_SPI2);
  13.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_SPI2);
  14.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  15.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  16.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  17.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  18.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  19.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  22.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  23.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  24.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//GPIO_PuPd_NOPULL;
  25.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  26.         //Cdfinger_BspCs_HIGH();
  27.         //Cdfinger_Bspdelay_ms(1);
  28.     Cdfinger_BspCs_LOW();
  29.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  30.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  31.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  32.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  33.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  34.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  35.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  36.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  37.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  38.         SPI_Init(SPI2, &SPI_InitStructure);
  39.         SPI_Cmd(SPI2, ENABLE);
  40.         /* DMA1 Stream0 channel4 spi tx configuration **************************************/
  41.         DMA_DeInit(DMA1_Stream4);
  42.         DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  43.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(SPI2->DR);
  44.         DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&cdfingerimgtxbuf[0];
  45.         DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  46.         DMA_InitStructure.DMA_BufferSize = 28*1024;
  47.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//;
  48.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  49.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  50.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  51.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;// ;
  52.         DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;//DMA_Priority_High;
  53.         DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;//DMA_FIFOMode_Enable;
  54.         DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  55.         DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  56.         DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  57.         DMA_Init(DMA1_Stream4, &DMA_InitStructure);
  58.         memset(cdfingerimgtxbuf,0x33,28*1024);
  59.     SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
  60.     DMA_Cmd(DMA1_Stream4, ENABLE);
  61.     while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE)==RESET);
发表于 2018-1-10 14:32:25 | 显示全部楼层
还没试过spi用dma发送
 楼主| 发表于 2018-1-10 16:03:13 | 显示全部楼层
flyleaf 发表于 2018-1-10 14:32
还没试过spi用dma发送
我也是第一次用,不知道为啥发不出来。
发表于 2019-6-3 10:52:23 | 显示全部楼层
楼主后来找到问题了吗?怎么解决的?方便参考下你的代码吗?
个人邮箱:leilei3507@126.com
GMT+8, 2024-5-7 09:04 , Processed in 0.027932 second(s), 23 queries , Gzip On.
