查看: 9954|回复: 4
hx711
发表于 2018-10-22 22:16:25 | 显示全部楼层 |阅读模式
#include "./hx711/hx711.h"
long HX711_Buffer = 0;
long Weight_Maopi = 0,Weight_Shiwu = 0;
#define GapValue 430
#define HIGH 1
#define LOW  0
#define HX711_GROUP GPIOB
void digitalWrite(GPIO_TypeDef * GPIO,int pin,int value)
        if(value==HIGH)//set 1
                GPIO_SetBits(GPIO,pin);
        if(value==LOW)//reset 0
                GPIO_ResetBits(GPIO,pin);
int digitalRead(GPIO_TypeDef * GPIO,int pin)
        return GPIO_ReadInputDataBit(GPIO,pin);
//初始化HX711
void Init_Hx711()
        GPIO_InitTypeDef  GPIO_InitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_GPIOA, ENABLE);
  //SCK
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 ;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_72MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
        GPIO_InitTypeDef  GPIO_InitStructure1;
  //DOUT
  GPIO_InitStructure1.GPIO_Pin = GPIO_Pin_1 ;
  GPIO_InitStructure1.GPIO_Mode = GPIO_Mode_IN;
  //GPIO_InitStructure1.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStructure1.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure1.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOA, &GPIO_InitStructure1);
//获取毛皮重量
void Get_Maopi()
        Weight_Maopi = HX711_Read();
//称重
long Get_Weight()
        HX711_Buffer = HX711_Read();
        Weight_Shiwu = HX711_Buffer;
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //获取实物的AD采样数值。
        Weight_Shiwu = (long)((float)Weight_Shiwu/GapValue);
        return Weight_Shiwu;
//读取HX711
unsigned long HX711_Read(void)        //增益128
                unsigned long val = 0;
        unsigned char i = 0;
        //判断模块是否准备好
        while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1));
        delay_us(1);
        //sck 拉低
        GPIO_ResetBits(GPIOA,GPIO_Pin_2);
        //再次判断是否准备好
        while(!GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1));
        for(i=0;i<24;i++)
                delay_us(100);
                GPIO_SetBits(GPIOA,GPIO_Pin_2);
                val=val<<1;
                delay_us(1);
                if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1))
                val++;
                delay_us(1);
        val = val^0x800000;
        delay_us(1);
        delay_us(1);
        return val;
中一直出现问题说没有被定义,问题是下面的
..\User\hx711\hx711.c(38): error:  #20: identifier "RCC_APB1Periph_GPIOA" is undefined
但是我定义了,而且在'".h"文件中也定义了#include "stm32f10x.h"。但是不知道为啥还是没有被定义,求大神
发表于 2018-10-23 08:36:27 | 显示全部楼层
RCC_APB1Periph_GPIOA-----RCC_APB2Periph_GPIOA
GPIO在APB2上
自己翻翻时钟树
发表于 2018-10-23 08:40:08 | 显示全部楼层
应该是RCC_APB2Periph_GPIOA
 楼主| 发表于 2018-10-23 10:20:22 | 显示全部楼层
确实是这样,谢谢
 楼主| 发表于 2018-10-23 10:20:47 | 显示全部楼层
GPIO在APB2上
谢谢,是这样的
GMT+8, 2024-5-20 07:29 , Processed in 0.029041 second(s), 24 queries , Gzip On.
