查看: 8684|回复: 2
刷外部flash
发表于 2018-11-30 22:21:33 | 显示全部楼层 |阅读模式
//要写入的数据的信息
Aux_Data_Typedef  burn_data[] =
  [AUX_XBF_XINSONGTI]         =
    .filename           =   "0:/srcdata/songti.xbf",
    .description        =   "XBF字库文件(emWin使用,新宋体.xbf)",
    .start_addr         =   60*4096 ,
    .length             =   317*4096,
        .burn_option              =          UPDATE,
  [AUX_HZLIB] =
    .filename           =   "0:/srcdata/HZLIB.bin",
    .description        =   "裸机中文字库(旧版,为兼容而保留)",
    .start_addr         =   1*4096 ,
    .length             =   53*4096,
  [AUX_GB2312] =
    .filename           =   "0:/srcdata/GB2312_H1616.FON",
    .description        =   "GB2312字库(修复HZLIB不支持标点的问题)",
    .start_addr         =   387*4096 ,
    .length             =   64*4096,
  [AUX_UNIGBK] =
    .filename           =   "0:/srcdata/UNIGBK.BIN",
    .description        =   "文件系统中文支持字库(emWin使用,UNIGBK.BIN)",
    .start_addr         =   465*4096 ,
    .length             =   43*4096,
  [AUX_FILE_SYSTEM] =
    .filename           =   "",
    .description        =   "FATFS文件系统",
    .start_addr         =   512*4096 ,
    .length             =   1536*4096,
    .burn_option      =  DO_NOT_UPDATE,
    .length             =   317*4096,
这里面这些是什么意思呀各位大佬,比如说 [AUX_XBF_XINSONGTI]         ={},这个实在不懂
发表于 2018-12-1 12:32:07 | 显示全部楼层
flash章节的视频有简单讲解这些内容,或者直接配合源码看
 楼主| 发表于 2018-12-1 16:24:36 | 显示全部楼层
我就是看了之后看的代码,发现这一部分不是很懂,求大神指教
GMT+8, 2024-5-5 09:12 , Processed in 0.110557 second(s), 23 queries , Gzip On.
