查看: 8841|回复: 2
请问下我的ADC是怎么回事?
发表于 2019-1-3 16:36:25 | 显示全部楼层 |阅读模式
用的是STM32F767,今天感觉ADC不对就去下载了ADC实验、内部温度传感器、DAC实验,
发现ADC采集到的电压总是在0.3v左右,感觉ADC坏了,我有换了ADC2.ADC3,结果是一样的,
而内部温度传感器ADC是正常的,采集到的温度是52度
那问题来了,到底是哪里坏了?
下面是我实物拍摄图,帮忙看下有没有接错了还是什么问题@老帖们@大佬
下面是源码:
#include "adc.h"
#include "delay.h"
//±¾3ìDòÖ»1©Ñ§Ï°ê1óã¬Î′¾-×÷ÕßDí¿é£¬2»μÃóÃóúÆäËüèÎoÎóÃí¾
//ALIENTEK STM32F7¿a·¢°å
//ADCÇy¶ˉ′úÂë
//ÕyμãÔ-×ó@ALIENTEK
//¼¼êõÂÛì3:
//′′½¨èÕÆú:2015/12/26
//°æ±¾£oV1.0
//°æè¨ËùóD£¬μá°æ±Ø¾¿¡£
//Copyright(C) 1ãÖYêDDÇòíμç×ó¿Æ¼¼óDÏT1«Ë¾ 2014-2024
//All rights reserved
ADC_HandleTypeDef ADC1_Handler;//ADC¾ä±ú
//3õê¼»ˉADC
//ch: ADC_channels
//í¨μàÖμ 0~16è¡Öμ·¶Î§Îa£oADC_CHANNEL_0~ADC_CHANNEL_16
void MY_ADC_Init(void)
    ADC1_Handler.Instance=ADC1;
    ADC1_Handler.Init.ClockPrescaler=ADC_CLOCK_SYNC_PCLK_DIV4;   //4·ÖÆ죬ADCCLK=PCLK2/4=108/4=27MHZ
    ADC1_Handler.Init.Resolution=ADC_RESOLUTION_12B;             //12λÄ£ê½
    ADC1_Handler.Init.DataAlign=ADC_DATAALIGN_RIGHT;             //óò¶ÔÆë
    ADC1_Handler.Init.ScanConvMode=DISABLE;                      //·Çé¨ÃèÄ£ê½
    ADC1_Handler.Init.EOCSelection=DISABLE;                      //1رÕEOCÖD¶Ï
    ADC1_Handler.Init.ContinuousConvMode=DISABLE;                //1رÕá¬Dø×a»»
    ADC1_Handler.Init.NbrOfConversion=1;                         //1¸ö×a»»Ôú1æÔòDòáDÖD ò2¾íêÇÖ»×a»»1æÔòDòáD1
    ADC1_Handler.Init.DiscontinuousConvMode=DISABLE;             //½ûÖ12»á¬Dø2éÑùÄ£ê½
    ADC1_Handler.Init.NbrOfDiscConversion=0;                     //2»á¬Dø2éÑùí¨μàêyÎa0
    ADC1_Handler.Init.ExternalTrigConv=ADC_SOFTWARE_START;       //èí¼t′¥·¢
    ADC1_Handler.Init.ExternalTrigConvEdge=ADC_EXTERNALTRIGCONVEDGE_NONE;//ê1óÃèí¼t′¥·¢
    ADC1_Handler.Init.DMAContinuousRequests=DISABLE;             //1رÕDMAÇëÇó
    HAL_ADC_Init(&ADC1_Handler);                                 //3õê¼»ˉ
//ADCμ×2ãÇy¶ˉ£¬òy½ÅÅäÖã¬ê±Öóê1Äü
//′Ëoˉêy»á±»HAL_ADC_Init()μ÷óÃ
//hadc:ADC¾ä±ú
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
    GPIO_InitTypeDef GPIO_Initure;
    __HAL_RCC_ADC1_CLK_ENABLE();            //ê1ÄüADC1ê±Öó
    __HAL_RCC_GPIOA_CLK_ENABLE();                        //¿aÆôGPIOAê±Öó
    GPIO_Initure.Pin=GPIO_PIN_5;            //PA5
    GPIO_Initure.Mode=GPIO_MODE_ANALOG;     //Ä£Äa
    GPIO_Initure.Pull=GPIO_NOPULL;          //2»′øéÏÏÂà-
    HAL_GPIO_Init(GPIOA,&GPIO_Initure);
//»ñμÃADCÖμ
//ch: í¨μàÖμ 0~16£¬è¡Öμ·¶Î§Îa£oADC_CHANNEL_0~ADC_CHANNEL_16
//·μ»ØÖμ:×a»»½á1û
u16 Get_Adc(u32 ch)
    ADC_ChannelConfTypeDef ADC1_ChanConf;
    ADC1_ChanConf.Channel=ch;                                   //í¨μà
    ADC1_ChanConf.Rank=1;                                       //1¸öDòáD
    ADC1_ChanConf.SamplingTime=ADC_SAMPLETIME_480CYCLES;        //2éÑùê±¼ä
    ADC1_ChanConf.Offset=0;
    HAL_ADC_ConfigChannel(&ADC1_Handler,&ADC1_ChanConf);        //í¨μàÅäÖÃ
    HAL_ADC_Start(&ADC1_Handler);                               //¿aÆôADC
    HAL_ADC_PollForConversion(&ADC1_Handler,10);                //ÂÖÑˉ×a»»
        return (u16)HAL_ADC_GetValue(&ADC1_Handler);                    //·μ»Ø×î½üò»′ÎADC11æÔò×éμÄ×a»»½á1û
//»ñè¡Ö¸¶¨í¨μàμÄ×a»»Ö죬è¡times′Î,è»oóƽ¾ù
//times:»ñè¡′Îêy
//·μ»ØÖμ:í¨μàchμÄtimes′Î×a»»½á1ûƽ¾ùÖμ
u16 Get_Adc_Average(u32 ch,u8 times)
        u32 temp_val=0;
        u8 t;
        for(t=0;t<times;t++)
                temp_val+=Get_Adc(ch);
                delay_ms(5);
        return temp_val/times;
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "lcd.h"
#include "sdram.h"
#include "adc.h"
ALIENTEK °¢2¨&#194;TSTM32F7&#191;a·¢°&#229; êμ&#209;é20
ADC&#196;£êy×a&#187;&#187;êμ&#209;é-HAL&#191;aoˉêy°&#230;
&#188;&#188;ê&#245;&#214;§3&#214;£
ì&#212;±|μê&#198;ì£o
1&#216;×¢&#206;¢D&#197;1&#171;&#214;ú&#198;&#189;ì¨&#206;¢D&#197;o&#197;£o"&#213;yμ&#227;&#212;-×ó"£&#172;&#195;a·&#209;&#187;&#241;è&#161;STM32×êá&#207;&#161;£
1&#227;&#214;YêDD&#199;òíμ&#231;×ó&#191;&#198;&#188;&#188;óD&#207;T1&#171;&#203;&#190;
×÷&#213;&#223;£o&#213;yμ&#227;&#212;-×ó @ALIENTEK
    u16 adcx;
        float temp;
    Cache_Enable();                 //′ò&#191;aL1-Cache
    HAL_Init();                                        //3&#245;ê&#188;&#187;ˉHAL&#191;a
    Stm32_Clock_Init(432,25,2,9);   //éè&#214;&#195;ê±&#214;ó,216Mhz
    delay_init(216);                //&#209;óê±3&#245;ê&#188;&#187;ˉ
        uart_init(115200);                        //′&#174;&#191;ú3&#245;ê&#188;&#187;ˉ
    LED_Init();                     //3&#245;ê&#188;&#187;ˉLED
    KEY_Init();                     //3&#245;ê&#188;&#187;ˉ°′&#188;ü
    SDRAM_Init();                   //3&#245;ê&#188;&#187;ˉSDRAM
    LCD_Init();                     //LCD3&#245;ê&#188;&#187;ˉ
    MY_ADC_Init();                  //3&#245;ê&#188;&#187;ˉADC1í¨μà5
        POINT_COLOR=RED;
        LCD_ShowString(30,50,200,16,16,"Apollo STM32F4/F7");
        LCD_ShowString(30,70,200,16,16,"ADC TEST");
        LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(30,110,200,16,16,"2016/7/12");
        POINT_COLOR=BLUE;//éè&#214;&#195;×&#214;ì&#229;&#206;aà&#182;é&#171;
        LCD_ShowString(30,130,200,16,16,"ADC1_CH5_VAL:");
        LCD_ShowString(30,150,200,16,16,"ADC1_CH5_VOL:0.000V");        //&#207;è&#212;ú1ì&#182;¨&#206;&#187;&#214;&#195;&#207;&#212;ê&#190;D&#161;êyμ&#227;
        adcx=Get_Adc_Average(ADC_CHANNEL_5,20);//&#187;&#241;è&#161;í¨μà5μ&#196;×a&#187;&#187;&#214;μ£&#172;20′&#206;è&#161;&#198;&#189;&#190;ù
                LCD_ShowxNum(134,130,adcx,4,16,0);    //&#207;&#212;ê&#190;ADCC2é&#209;ùoóμ&#196;&#212;-ê&#188;&#214;μ
                temp=(float)adcx*(3.3/4096);          //&#187;&#241;è&#161;&#188;&#198;&#203;&#227;oóμ&#196;′&#248;D&#161;êyμ&#196;êμ&#188;êμ&#231;&#209;1&#214;μ£&#172;±èè&#231;3.1111
                adcx=temp;                            //&#184;3&#214;μ&#213;&#251;êy2&#191;·&#214;&#184;&#248;adcx±&#228;á&#191;£&#172;òò&#206;aadcx&#206;au16&#213;&#251;D&#206;
                LCD_ShowxNum(134,150,adcx,1,16,0);    //&#207;&#212;ê&#190;μ&#231;&#209;1&#214;μμ&#196;&#213;&#251;êy2&#191;·&#214;£&#172;3.1111μ&#196;&#187;°£&#172;&#213;aà&#239;&#190;íê&#199;&#207;&#212;ê&#190;3
                temp-=adcx;                           //°&#209;ò&#209;&#190;-&#207;&#212;ê&#190;μ&#196;&#213;&#251;êy2&#191;·&#214;è¥μ&#244;£&#172;á&#244;&#207;&#194;D&#161;êy2&#191;·&#214;£&#172;±èè&#231;3.1111-3=0.1111
                temp*=1000;                           //D&#161;êy2&#191;·&#214;3&#203;ò&#212;1000£&#172;àyè&#231;£o0.1111&#190;í×a&#187;&#187;&#206;a111.1£&#172;&#207;àμ±óú±£á&#244;èy&#206;&#187;D&#161;êy&#161;£
                LCD_ShowxNum(150,150,temp,3,16,0X80); //&#207;&#212;ê&#190;D&#161;êy2&#191;·&#214;£¨&#199;°&#195;&#230;×a&#187;&#187;&#206;aá&#203;&#213;&#251;D&#206;&#207;&#212;ê&#190;£&#169;£&#172;&#213;aà&#239;&#207;&#212;ê&#190;μ&#196;&#190;íê&#199;111.
                LED0_Toggle;
                delay_ms(250);
发表于 2019-1-4 08:46:05 | 显示全部楼层
估计是板子坏了
发表于 2019-1-4 08:48:17 | 显示全部楼层
你是用野火的例程下载进正点的板子?你注意下引脚的配置哦
GMT+8, 2024-5-9 04:23 , Processed in 0.030461 second(s), 23 queries , Gzip On.
