查看: 7693|回复: 3
fatfs移植 f_mount提示底层io代码出错,求大佬帮忙看看那里错了!!!
发表于 2019-6-18 17:43:38 | 显示全部楼层 |阅读模式
在调用挂在函数f_mount时,返回值是  FR_DISK_ERR,                        /* (1) A hard error occurred in the low level disk I/O layer */
所以应该是底层函数挂了,spi_flash的函数都是正常的,测试过。求大佬帮忙看看是哪儿出错了!!!!
我的底层函数如下:
[mw_shl_code=c,true]DSTATUS disk_status (
        BYTE pdrv                /* Physical drive nmuber to identify the drive */
        uint32_t result;
        switch (pdrv) {
        case SD_CARD:
//                result = ATA_disk_status();
                // translate the reslut code here
        case FLASH_MEMORY:
//                result = MMC_disk_status();
                result = SPI_FLASH_ReadId();
                if(result == 0xef4017)
                        return 0;
                        return STA_NOINIT;
        default:
                return STA_NOINIT;
/* Inidialize a Drive                                                    */
DSTATUS disk_initialize (
        switch (pdrv) {
        case SD_CARD:
//                result = ATA_disk_initialize();
        case FLASH_MEMORY:
//                result = MMC_disk_initialize();
                SPI_FALSH_GPIO_Config();
                SPI_FLASH_Config();
                SPI_Flash_WAKEUP();
                return disk_status(FLASH_MEMORY);
        default:
                return STA_NOINIT;
/* Read Sector(s)                                                        */
DRESULT disk_read (
        BYTE pdrv,                /* Physical drive nmuber to identify the drive */
        BYTE *buff,                /* Data buffer to store read data */
        DWORD sector,        /* Sector address in LBA */
        UINT count                /* Number of sectors to read */
        DRESULT res;
        switch (pdrv) {
        case SD_CARD:
                // translate the arguments here
//                result = ATA_disk_read(buff, sector, count);
        case FLASH_MEMORY:
//                result = MMC_disk_read(buff, sector, count);
                SPI_FLASH_ReadByte(sector << 12, buff, count << 12);
                res = RES_OK;
                return res;
        default :
                        return RES_PARERR;
/* Write Sector(s)                                                       */
#if _USE_WRITE
DRESULT disk_write (
        const BYTE *buff,        /* Data to be written */
        UINT count                        /* Number of sectors to write */
        DRESULT res;
        switch (pdrv) {
        case SD_CARD :
//                result = ATA_disk_write(buff, sector, count);
                return res;
        case FLASH_MEMORY :
//                result = MMC_disk_write(buff, sector, count);
                SPI_FALSH_Erase_Sector(sector<< 12);
                SPI_FLASH_WritBytes(sector<< 12, (uint8_t*)buff, count<< 12);
                res = RES_OK;
                return res;
        default :
                return RES_PARERR;
#endif
/* Miscellaneous Functions                                               */
#if _USE_IOCTL
DRESULT disk_ioctl (
        BYTE pdrv,                /* Physical drive nmuber (0..) */
        BYTE cmd,                /* Control code */
        void *buff                /* Buffer to send/receive control data */
        DRESULT res;
        switch (pdrv) {
        case SD_CARD :
                // Process of the command for the ATA drive
                return res;
        case FLASH_MEMORY :
                // Process of the command for the MMC/SD card
                switch(cmd)
                        case GET_SECTOR_COUNT:
                                *(DWORD* )buff = 2048;
                                break;
                        case GET_SECTOR_SIZE:
                                *(WORD*)buff = 4096;
                                break;
                        case GET_BLOCK_SIZE:
                                *(DWORD* )buff = 1;
                                break;
                return res;
        default :
                return RES_PARERR;
#endif[/mw_shl_code]
发表于 2019-6-19 15:08:14 | 显示全部楼层
还要看看你ioctl函数是怎么写的
 楼主| 发表于 2019-6-30 20:42:25 | 显示全部楼层
过了好多天才上来看,对不住楼上大佬
 楼主| 发表于 2019-6-30 20:43:15 | 显示全部楼层
改成每个函数只有一个return 后可以使用了,应该是某处逻辑错误
GMT+8, 2024-5-5 00:05 , Processed in 0.028009 second(s), 23 queries , Gzip On.
