查看: 10756|回复: 2
DMA中断+ADC+TIM进行ADC采样出现问题
发表于 2019-8-8 18:32:18 | 显示全部楼层 |阅读模式
单独用ADC+TIM+DMA没有问题,可以采集,但是加上DMA中断后就不行了 串口一直输出的是一个定值  比如0X0FFF 求大神指点迷津  代码如下
static void Rheostat_ADC_GPIO_Config(void)
        RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_GPIO_CLK, ENABLE);
        GPIO_InitStructure.GPIO_Pin = RHEOSTAT_ADC_GPIO_PIN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; //2»éÏà-2»ÏÂà-
        GPIO_Init(RHEOSTAT_ADC_GPIO_PORT, &GPIO_InitStructure);
static void Rheostat_ADC_Mode_Config(void)
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
        NVIC_InitTypeDef NVIC_InitStruct;
        RCC_APB2PeriphClockCmd(RHEOSTAT_ADC_CLK , ENABLE);
  RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_DMA_CLK, ENABLE);
        DMA_InitStructure.DMA_PeripheralBaseAddr = RHEOSTAT_ADC_DR_ADDR;
        DMA_InitStructure.DMA_Memory0BaseAddr = (u32)&ADC_ConvertedValue;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_InitStructure.DMA_BufferSize = 1;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode =DMA_Mode_Circular;//DMA_Mode_Normal;// DMA_Mode_Circular;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_Channel = RHEOSTAT_ADC_DMA_CHANNEL;
        DMA_Init(RHEOSTAT_ADC_DMA_STREAM, &DMA_InitStructure);
        NVIC_InitStruct.NVIC_IRQChannel=DMA2_Stream0_IRQn;
        NVIC_InitStruct.NVIC_IRQChannelCmd=ENABLE;
        NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority=1;
        NVIC_InitStruct.NVIC_IRQChannelSubPriority=0;
        NVIC_Init(&NVIC_InitStruct);
  DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TC);                             //Çå3yÖD¶Ï±êÖ¾
        DMA_ITConfig(RHEOSTAT_ADC_DMA_STREAM,DMA_IT_TC,ENABLE);  //ê1Äü·¢ËíÖD¶Ï
        DMA_Cmd(DMA2_Stream0, ENABLE);
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
        ADC_StructInit(&ADC_InitStructure);
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T4_CC4;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(RHEOSTAT_ADC, &ADC_InitStructure);
  ADC_RegularChannelConfig(RHEOSTAT_ADC, RHEOSTAT_ADC_CHANNEL, 1, ADC_SampleTime_3Cycles);
  ADC_DMARequestAfterLastTransferCmd(RHEOSTAT_ADC, ENABLE);
  ADC_DMACmd(RHEOSTAT_ADC, ENABLE);
  ADC_Cmd(RHEOSTAT_ADC, ENABLE);
  ADC_SoftwareStartConv(RHEOSTAT_ADC);
void MY_Time(u16 sample)
  RCC_APB1PeriphClockCmd(GENERAL_TIM_CLK, ENABLE);
  TIM_TimeBaseStructure.TIM_Period =  (10000-1)/sample;
  TIM_TimeBaseStructure.TIM_Prescaler = 9000-1;
  TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(GENERAL_TIM, &TIM_TimeBaseStructure);
        TIM_OCStructInit(&TIM_OCInitStructure);                       //éèÖÃè±ê¡Öμ,Õaò»2½×îoüóéÏ·àÖ1·Åμ½′®¿ú3õê¼»ˉoó3öÎêìa
  TIM_OCInitStructure.TIM_Pulse = 90000000/sample/2;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC4Init(GENERAL_TIM, &TIM_OCInitStructure);
        TIM_OC4PreloadConfig(GENERAL_TIM, TIM_OCPreload_Enable);
        TIM_Cmd(GENERAL_TIM, ENABLE);
        TIM_CtrlPWMOutputs(GENERAL_TIM, ENABLE);
  * @brief  ADC13õê¼»ˉ
  * @param  ÎT
  * @retval ÎT
void Rheostat_Init(void)
        Rheostat_ADC_GPIO_Config();
        Rheostat_ADC_Mode_Config();
void DMA2_Stream0_IRQHandler()
         if(DMA_GetITStatus(RHEOSTAT_ADC_DMA_STREAM,DMA_IT_TCIF0)) //ÅD¶ÏêÇ·ñÎaDMA1·¢Ëííê3éÖD¶Ï;
    DMA_ClearITPendingBit( DMA2_Stream0 ,DMA_IT_TCIF0);
                DMA_Cmd(RHEOSTAT_ADC_DMA_STREAM, ENABLE);        //1رÕDMA;
                ADC_Flag=1;
    /*3õê¼»ˉUSART1*/
    Debug_USART_Config();
             Rheostat_Init();
          MY_Time(20000);
    while (1)
      ADC_ConvertedValueLocal =(float) ADC_ConvertedValue/4096*(float)3.3; // ¶áè¡×a»»μÄADÖμ
      printf("\r\n The current AD value = 0x%04X \r\n", ADC_ConvertedValue);
      printf("\r\n The current AD value = %f V \r\n",ADC_ConvertedValueLocal);
      Delay(0xffffee);
static void Delay(__IO uint32_t nCount)         //¼òμ¥μÄÑóê±oˉêy
        for(; nCount != 0; nCount--);
发表于 2019-8-8 22:50:28 | 显示全部楼层
ADC_Flag有什么用,这里的DMA中断是想做什么呢
 楼主| 发表于 2019-8-9 01:46:09 | 显示全部楼层
关闭DMA传输  对数据做处理
GMT+8, 2024-5-6 05:51 , Processed in 0.025609 second(s), 23 queries , Gzip On.
