查看: 18163|回复: 2
规则同步ADC+DMA,数据DMA传输问题
发表于 2020-3-21 17:27:38 | 显示全部楼层 |阅读模式
    配置ADC模块多通道、规则同步模式,用DMA来传输采样数据后,发现获得通道数据被打乱。如按配置上
        ADC_VALUE[0] = ADC1 Channel10 的数据
        ADC_VALUE[1] = ADC1 Channel12 的数据
        ADC_VALUE[2] = ADC1 Channel11 的数据
        ADC_VALUE[3] = ADC1 Channel13 的数据
    但实际得到的数据不是上述对应关系,且是变化的,不知是何缘故,求教各位大佬!!!!
    程序如下所示,但是忽略其他无关程序语段。
    volatile uint16_t  ADC_VALUE[4];
void DMA_S12AD_Config(void)
    DMA_InitTypeDef  DMA_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
    DMA_InitStructure.DMA_Channel                   = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr   = (uint32_t)ADC_CCR_ADDRESS;
    DMA_InitStructure.DMA_Memory0BaseAddr    = (uint32_t)ADC_VALUE;
    DMA_InitStructure.DMA_DIR                         = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize                = 4;
    DMA_InitStructure.DMA_PeripheralInc           = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc              = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize   = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize      = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode                      = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority                   = DMA_Priority_High;
    DMA_InitStructure.DMA_FIFOMode              = DMA_FIFOMode_Enable;
    DMA_InitStructure.DMA_FIFOThreshold        = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst          = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst       = DMA_PeripheralBurst_Single;
    DMA_Init(DMA2_Stream0, &DMA_InitStructure);
/* DMA2_Stream0 enable */
DMA_Cmd(DMA2_Stream0, ENABLE);
void S12AD_REnc_Config(void)
ADC_InitTypeDef   ADC_InitStructure;
ADC_CommonInitTypeDef  ADC_CommonInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2,ENABLE);
ADC_CommonInitStructure.ADC_Mode                   = ADC_DualMode_RegSimult;
ADC_CommonInitStructure.ADC_Prescaler              = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode    = ADC_DMAAccessMode_1;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
// -------------------ADC Init ADC1 --------------------------------------------------------
ADC_InitStructure.ADC_Resolution                   = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode            = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode   = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge  = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_ExternalTrigConv         = ADC_ExternalTrigConv_T1_CC1;
ADC_InitStructure.ADC_DataAlign                   = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion         = 2;
/* ADC1 regular channels 10, 11 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_3Cycles);
// -------------------ADC Init ADC2 ------------------------------------------------------
ADC_Init(ADC2, &ADC_InitStructure);
/* ADC2 regular channels 12, 13 configuration */
ADC_RegularChannelConfig(ADC2, ADC_Channel_12, 1, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC2, ADC_Channel_13, 2, ADC_SampleTime_3Cycles);
/* Enable DMA request after last transfer (Multi-ADC mode) */
ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC2, ENABLE);
void PORT_Config(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);           // GPCIOC clock
// PC0 ADC123_IN10
GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AIN;
GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
//PC1 ADC123_IN11
GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_1;
//PC2 ADC123_IN12
GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_2;
//PC3 ADC123_IN13
GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_3;
    PORT_Config();
    DMA_S12AD_Config();
    S12AD_REnc_Config();
    /* Start ADC1 Software Conversion */
    ADC1->CR2 |= (uint32_t)ADC_CR2_SWSTART;
    while(1) ;
 楼主| 发表于 2020-3-25 19:38:51 | 显示全部楼层
现已查明:非AD/DMA配置问题,是创建工程包含文件错误。
发表于 2020-10-21 16:29:03 | 显示全部楼层
Alex.Wong 发表于 2020-3-25 19:38
**** 作者被禁止或删除 内容自动屏蔽 ****
你好,我好像也遇到了这个问题:DMA传输到内存的数据会出现错位,数据索引会随着时间变化。
请问你发现是哪里的原因?
GMT+8, 2024-5-3 02:39 , Processed in 0.035276 second(s), 24 queries , Gzip On.
