查看: 9578|回复: 0
使用image builder构建image失败
发表于 2020-5-2 22:22:31 | 显示全部楼层 |阅读模式
系统为ubuntu 18.04 server,根据指南: https://tutorial.linux.doc.embedfire.com/zh_CN/latest/building_image/building_debian.html,编译出了uboot和kernel, 然后拷贝至uboot目录和Kernel目录,
接下来的sd image编译失败, 看了一下log, 提示有如下错误:
1.
getauxval () failed: No such file or directory
qemu: uncaught target signal 5 (Trace/breakpoint trap) - core dumped
2.
tar: ./usr/share/man/man1/dconf-service.1.gz: Cannot write: No space left on device
tar: ./usr/share/man/man1/connmanctl.1.gz: Cannot write: No space left on device
tar: ./usr/share/man/man1/mountpoint.1.gz: Cannot write: No space left on device
tar: ./var/opt: Cannot mkdir: No such file or directory
tar: Exiting with failure status due to previous errors
./publish/seeed-imx-stable.sh: line 22:  6775 Terminated              keep_net_alive  (wd: /home/fire/ebf-image-builder)
以及如下警告:
W: Download is performed unsandboxed as root as file '/var/lib/apt/lists/partial/mirrors.tuna.tsinghua.edu.cn_debian_dists_buster_InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
ebf-image-builder_230.zip
178.57 KB, 下载次数: 1
编译过程log
GMT+8, 2024-5-22 10:35 , Processed in 0.032638 second(s), 26 queries , Gzip On.
