查看: 12857|回复: 2
[已解决] sudo apt install peripheral 安装出错
发表于 2020-5-17 13:46:40 | 显示全部楼层 |阅读模式
大家好,
   我跟着野火linux视频,第23讲用脚本体验硬件,遇到 sudo apt install peripheral 安装出错,如下所示:
debian@npi:~$ sudo apt install peripheral
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  peripheral
0 upgraded, 1 newly installed, 0 to remove and 18 not upgraded.
Need to get 182 kB of archives.
After this operation, 0 B of additional disk space will be used.
Err:1 https://wildfireteam.gitee.io buster/main armhf peripheral armhf 0.1.4
  404  Not Found [IP: 212.64.62.174 443]
E: Failed to fetch https://wildfireteam.gitee.io/po ... ral_0.1.4_armhf.deb  404  Not Found [IP: 212.64.62.174 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
debian@npi:~$
还有有一个疑惑,视频中的sudo apt update 命令是不是只会检查更新,如果是的话如何进行真正的跟新。
谢谢!
安装失败
安装失败
发表于 2020-5-18 08:46:23 | 显示全部楼层
https://www.firebbs.cn/forum.php ... id=29505&extra=
参考上面的帖子,改一下软件源:https://Embedfire.github.io/
更新软件的话,是执行:apt upgrade
 楼主| 发表于 2020-5-18 22:55:49 | 显示全部楼层
谢谢!
GMT+8, 2024-5-18 15:32 , Processed in 0.039417 second(s), 28 queries , Gzip On.
