查看: 19141|回复: 0
keil自带的模拟示波器输出的频率不符合程序设置
发表于 2020-11-15 11:11:00 | 显示全部楼层 |阅读模式
  1. [code]
  2. //TIM1_单通道输出PWM信号
  3. #include"bsp_advance.h"
  4. static void ADVANCE_TIM_GPIO_Config(void)
  5. {
  6.         GPIO_InitTypeDef GPIO_InitStructure;
  7.
  8.         //输出通道GPIO_PA8
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  10.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8;
  11.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  12.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13.
  14.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  15. }
  16. static void ADVANCE_TIM_Mode_Config(void)
  17. {
  18.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
  19.         //配置时基结构体
  20.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  21.
  22.         TIM_TimeBaseStructure.TIM_Period=899;
  23.         TIM_TimeBaseStructure.TIM_Prescaler=0;
  24.         TIM_TimeBaseStructure.TIM_ClockDivision=0;
  25.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  26.         TIM_TimeBaseStructure.TIM_RepetitionCounter=0;
  27.
  28.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  29.
  30.         //配置输出比较结构体
  31.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  32.
  33.   TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;
  34.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  35.         TIM_OCInitStructure.TIM_Pulse =449;
  36.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  37.
  38.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);
  39.
  40.         TIM_CtrlPWMOutputs(TIM1, ENABLE);
  41.
  42.         TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
  43.
  44.         TIM_ARRPreloadConfig(TIM1, ENABLE);
  45.
  46.         TIM_Cmd(TIM1, ENABLE);
  47. }
  48.
  49. void ADVANCE_TIM_Init(void)
  50. {
  51.         ADVANCE_TIM_GPIO_Config();
  52.         ADVANCE_TIM_Mode_Config();
  53. }
GMT+8, 2024-5-5 11:41 , Processed in 0.032607 second(s), 26 queries , Gzip On.
