查看: 20020|回复: 0
[求助] imx6ull pro 网口起不来的问题
发表于 2020-12-10 21:07:35 | 显示全部楼层 |阅读模式
pro开发板网口接eth2可以link up,但是配置的静态IP没有,eth1启动失败,网络接口的灯不亮,可能会是什么原因,因为之前是OK的,之后测试过SD卡启动,再回到emmc启动,网络就有点问题了?
root@npi:/etc/network# systemctl status networking
¡ñ networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor prese
   Active: failed (Result: timeout) since Thu 2020-12-10 12:56:34 UTC; 7min ago
     Docs: man:interfaces(5)
  Process: 8572 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=
Main PID: 8572 (code=exited, status=1/FAILURE)
   CGroup: /system.slice/networking.service
Dec 10 12:56:33 npi ifup[8572]: DHCPDISCOVER on eth1 to 255.255.255.255 port 67
Dec 10 12:56:33 npi dhclient[8587]: Sending on   LPF/eth1/a2:a1:a0:ed:8c:92
Dec 10 12:56:33 npi dhclient[8587]: Sending on   Socket/fallback
Dec 10 12:56:33 npi dhclient[8587]: DHCPDISCOVER on eth1 to 255.255.255.255 port
Dec 10 12:56:34 npi systemd[1]: networking.service: Start operation timed out. T
Dec 10 12:56:34 npi ifup[8572]: Got signal Terminated, terminating...
Dec 10 12:56:34 npi ifup[8572]: ifup: failed to bring up eth1
Dec 10 12:56:34 npi systemd[1]: networking.service: Main process exited, code=ex
Dec 10 12:56:34 npi systemd[1]: networking.service: Failed with result 'timeout'
Dec 10 12:56:34 npi systemd[1]: Failed to start Raise network interfaces.
GMT+8, 2024-5-18 08:39 , Processed in 0.028486 second(s), 27 queries , Gzip On.
