查看: 3835|回复: 4
[freertos] 任务优先级的问题。
发表于 2022-6-10 15:17:51 | 显示全部楼层 |阅读模式
smt32单片机freertos操作系统中空闲任务的优先级设置为时,系统无法切换到Idle任务,切换时进入HardFault_Handler异常,打不到任务空闲任务块。有没有人遇到过这种情况?
发表于 2022-6-11 17:11:02 | 显示全部楼层
截图初始化和各个任务部分的代码
 楼主| 发表于 2022-6-14 08:20:23 | 显示全部楼层
*                        任务控制块 & STACK
TCB_t Task1TCB,Task2TCB;
#define TASK1_STACK_SIZE                    20
StackType_t Task1Stack[TASK1_STACK_SIZE];
#define TASK2_STACK_SIZE                    20
StackType_t Task2Stack[TASK2_STACK_SIZE];
//定义任务控制块
TCB_t Task1TCB;
TCB_t Task2TCB;
//定义任务句柄
TaskHandle_t Task1_Handle;
TaskHandle_t Task2_Handle;
*                               函数声明
void delay (uint32_t count);
void Task1_Entry( void *p_arg );
void Task2_Entry( void *p_arg );
int  main(void){
         prvInitialiseTaskLists( );   //初始化就绪列表
        Task1_Handle =xTaskCreateStatic(Task1_Entry,
        "Task1_Entry",
                           TASK1_STACK_SIZE,
        NULL,
        2,
        Task1Stack,
                            &Task1TCB
        //vListInsert(&pxReadyTasksLists[1],&Task1TCB.xStateListItem);
        Task2_Handle =xTaskCreateStatic(Task2_Entry,
        "Task2_Entry",
                           TASK2_STACK_SIZE,
        NULL,
        1,
        Task2Stack,
                            &Task2TCB
        //vListInsert(&pxReadyTasksLists[2],&Task2TCB.xStateListItem);
            /* 在启动调度器前,关闭中断 */
   portDISABLE_INTERRUPTS();
        vTaskStartScheduler();
while(1){
//定义一个任务函数
/* 软件延时 */
        for(; count!=0; count--);
void Task1_Entry(void *p_arg)
{for(;;)
        { flag1 = 1;
                vTaskDelay( 2 );
                flag1 = 0;
                vTaskDelay( 2);
                //taskYIELD();
void Task2_Entry(void *p_arg)
{for(;;)
        {flag2 = 1;
                vTaskDelay( 2 );
        flag2 = 0;
                vTaskDelay( 2 );
StackType_t IdleTaskStack[configMINIMAL_STACK_SIZE];
TCB_t IdleTaskTCB;
void vApplicationGetIdleTaskMemory( TCB_t **ppxIdleTaskTCBBuffer,
                                    StackType_t **ppxIdleTaskStackBuffer,
                                    uint32_t *pulIdleTaskStackSize )
                *ppxIdleTaskTCBBuffer=&IdleTaskTCB;
                *ppxIdleTaskStackBuffer=IdleTaskStack;
                *pulIdleTaskStackSize=configMINIMAL_STACK_SIZE;
 楼主| 发表于 2022-6-14 08:20:45 | 显示全部楼层
以上为主函数
 楼主| 发表于 2022-6-14 08:22:01 | 显示全部楼层
把task1和task2的任务优先级调换一下,程序运行又可以正常了。
GMT+8, 2024-5-7 02:25 , Processed in 0.040897 second(s), 23 queries , Gzip On.
