查看: 864|回复: 6
[求助] 8月3号Debian镜像通过SD卡启动报错
发表于 2023-8-8 22:53:09 | 显示全部楼层 |阅读模式
SD卡烧录的8月3号的debian镜像会报这个错误
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[FAILED] Failed to start Raise network interfaces.
See 'systemctl status networking.service' for details.
发表于 2023-8-10 19:48:13 | 显示全部楼层
貌似不影响驱动加载和网络。后续再改下
可以先用usb的,那个不会有这个报错
 楼主| 发表于 2023-8-10 22:31:23 | 显示全部楼层
目前使用USB烧录系统到emmc中,还是会有报错
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
         Starting Terminate Psplash Act Screen...
[  OK  ] Started System Logging Service.
[  OK  ] Started rng-tools.service.
[  OK  ] Started WPA supplicant.
[  OK  ] Started Login Service.
[  OK  ] Started LSB: Start busybox udhcpd at boot time.
[FAILED] Failed to start Generic Board Startup.
See 'systemctl status generic-board-startup.service' for details.
[  OK  ] Started Connection service.
[  OK  ] Reached target Network.
         Starting =booting wifi ......
         Starting Permit User Sessions...
         Starting Hostname Service...
[  OK  ] Started Permit User Sessions.
配置静态IP地址的时候 也会报错
root@npi:~# /etc/init.d/networking restart
Restarting networking (via systemctl): networking.serviceJob for networking.service failed because the control process exited with error code.
See "systemctl status networking.service" and "journalctl -xe" for details.
failed!
root@npi:~# systemctl status networking.service
● networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor prese
   Active: failed (Result: exit-code) since Thu 2023-08-10 14:24:16 UTC; 32s ago
     Docs: man:interfaces(5)
  Process: 596 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1
Main PID: 596 (code=exited, status=1/FAILURE)
Aug 10 14:24:16 npi systemd[1]: Starting Raise network interfaces...
Aug 10 14:24:16 npi ifup[596]: RTNETLINK answers: File exists
Aug 10 14:24:16 npi ifup[596]: ifup: failed to bring up eth1
Aug 10 14:24:16 npi systemd[1]: networking.service: Main process exited, code=ex
Aug 10 14:24:16 npi systemd[1]: networking.service: Failed with result 'exit-cod
Aug 10 14:24:16 npi systemd[1]: Failed to start Raise network interfaces.
 楼主| 发表于 2023-8-10 23:00:09 | 显示全部楼层
开发板 重启后,网络部分不报错了,配置的静态IP地址也生效了
发表于 2023-8-12 10:27:43 | 显示全部楼层
如果要sd卡刷emmc/nand,镜像要更新下,之前sd卡镜像貌似没替换成功内核,usb的是替换成功的,sd卡的今天改了好了
发表于 2023-8-12 10:28:39 | 显示全部楼层
上面网络和板级初始化服务貌似20年5月份镜像就有问题了,但实际却又不影响
 楼主| 发表于 2023-8-15 21:26:04 | 显示全部楼层
目前多次测试下来,通过ifconfig命令配置静态IP能够生效,重新上电恢复默认IP。通过修改/etc/network/interface配置文件的方式始终无效
GMT+8, 2024-5-6 15:00 , Processed in 0.057323 second(s), 33 queries , Gzip On.
