查看: 9913|回复: 0
有谁做过1w led调光的?现在我的PWM输出极其不稳定
发表于 2014-11-25 18:22:50 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#include  <math.h>
#include  <stdio.h>
#define uint unsigned int
#define uchar unsigned char
sbit rs=P1^7;
sbit rw=P1^6;
sbit en=P1^5;
sbit pwm1=P2^0;
sbit pwm2=P2^1;
sbit pwm3=P2^2;
sbit xh=P1^3;
sbit key1=P2^3;
sbit key2=P2^4;
sbit SCL=P1^0;
sbit SDA=P1^1;
uchar x,q,numm;
uchar gg[13]={"1a&#213;&#213;&#199;&#191;&#182;è£o000"};
uchar tt[16]={"è&#203;ì&#229;oìía&#184;Dó|μ÷1a"};
uchar rr[11]={"è&#203;á÷á&#191;£o000"};
void delayg(uint z)
        uchar i;
        for(i=z;i>0;i--)
                _nop_();
                _nop_();
                _nop_();
                //_nop_();
                //_nop_();
                //_nop_();
                //_nop_();
                //_nop_();
void delayms(uint z)
        uint i,j;
        for(i=z;i>0;i--)
                for(j=110;j>0;j--);
void delay(uint z)
        uint i,j;
        for(i=z;i>0;i--)
                for(j=110;j>0;j--);
#define          SlaveAddress   0x46
typedef  unsigned char BYTE;
typedef  unsigned short WORD;
BYTE BUF[8];
int  dis_data;
void delay_nms(unsigned int k)
        uint i,j;
        for(i=k;i>0;i--)
                for(j=110;j>0;j--);
void key()
        if(key1==0)
                delay(100);
                if(key1==0)
                        delay(5);
                        x++;
                        q++;
   if(key2==0)
                delay(100);
                if(key2==0)
                                delay(5);
                                x--;
                                q--;
void jiance()
        if(xh==1)
                delay(1950);
                if(xh==1)
                        x++;
                        q++;
void qudong()
        uchar i,j;
        for(i=x;i>0;i--)
                pwm1=1;
                pwm2=1;
                pwm3=1;
          delayms(100);
        for(j=(10-x);j>0;j--)
                pwm1=0;
                pwm2=0;
                pwm3=0;
                delayg(100);
void Delay5us()
   _nop_();
         _nop_();
         _nop_();
         _nop_();
   //_nop_();
         //_nop_();
         //_nop_();
         //_nop_();
void Delay5ms()
         uchar n=560;
   while (n--);
void BH1750_Start()
    SDA = 1;
    SCL = 1;
    Delay5us();
    SDA = 0;
    Delay5us();
    SCL = 0;
void BH1750_Stop()
    SDA = 0;
    SCL = 1;
    Delay5us();
    SDA = 1;
    Delay5us();
void BH1750_SendACK(bit ack)
    SDA = ack;
    SCL = 1;
    Delay5us();
    SCL = 0;
    Delay5us();
bit BH1750_RecvACK()
    SCL = 1;
    Delay5us();
    CY = SDA;
    SCL = 0;
    Delay5us();
    return CY;
void BH1750_SendByte(BYTE dat)
    BYTE i;
    for (i=0; i<8; i++)
        dat <<= 1;
        SDA = CY;
        SCL = 1;
        Delay5us();
        SCL = 0;
        Delay5us();
    BH1750_RecvACK();
BYTE BH1750_RecvByte()
    BYTE i;
    BYTE dat = 0;
    SDA = 1;
    for (i=0; i<8; i++)
        dat <<= 1;
        SCL = 1;
        Delay5us();
        dat |= SDA;
        SCL = 0;
        Delay5us();
    return dat;
void Single_Write_BH1750(uchar REG_Address)
    BH1750_Start();
    BH1750_SendByte(SlaveAddress);
    BH1750_SendByte(REG_Address);
    BH1750_Stop();
void Multiple_read_BH1750()
{   uchar i;
    BH1750_Start();
    BH1750_SendByte(SlaveAddress+1);
         for (i=0; i<3; i++)
        BUF[i] = BH1750_RecvByte();
        if (i == 3)
           BH1750_SendACK(1);
          BH1750_SendACK(0);
    BH1750_Stop();
    Delay5ms();
void Init_BH1750()
   Single_Write_BH1750(0x01);
uchar huoqu()
                float temp;
    Single_Write_BH1750(0x10);
                delay_nms(180);
                Multiple_Read_BH1750();
    dis_data=BUF[0];
    dis_data=(dis_data<<8)+BUF[1];
    temp=(float)dis_data/1.2;
    return temp;
void change ()
        rr[8]=q/100+0x30;
        rr[9]=q/10%10+0x30;
        rr[10]=q%10+0x30;
void change1()
        uchar temp;
        temp=(uchar)huoqu();
        gg[10]=(uchar)temp/100+0x30;
        gg[11]=(uchar)temp%100/10+0x30;
        gg[12]=(uchar)temp%10+0x30;
void writecom (uchar com)
        rs=0;
        en=0;
        P0=com;
  delayms(1);
        en=1;
        delayms(1);
  en=0;
void writedata (uchar date)
        rs=1;
        en=0;
        P0=date;
        delayms(1);
        en=1;
  delayms(1);
        en=0;
void init12864 ()
        rw=0;
        writecom(0x30);
        delayms(1);
        writecom(0x01);
        delayms(1);
        writecom(0x06);
        delayms(1);
        writecom(0x0c);
        delayms(1);
void place (uchar x,uchar y)
        uchar pos;
        if(x==0)
                x=0x80;
        if(x==1)
                x=0x90;
        if(x==2)
                x=0x88;
        if(x==3)
                x=0x98;
        pos=x+y;
        writecom(pos);
void xianshi()
        uchar i;
        place(1,5);
        for(i=10;i<13;i++)
                writedata(gg[i]);
        place(2,4);
        for(i=8;i<11;i++)
                writedata(rr[i]);
void tiaozheng()
        if(x==11)
                x=0;
void initzd()
        TMOD=0X01;
        EA=1;
        ET0=1;
        TR0=1;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
main()
        uchar i;
        Init_BH1750();
        init12864();
        initzd();
        place(2,0);
        for(i=0;i<8;i++)
                writedata(rr[i]);
        place(0,0);
        for(i=0;i<16;i++)
                writedata(tt[i]);
        place(1,0);
        for(i=0;i<10;i++)
                writedata(gg[i]);
                //xianshi();
                //jiance();
                //qudong();
                change();
                key();
                tiaozheng();
                qudong();
void enter0() interrupt 1
        //xianshi();
        numm++;
        if(numm==4)
                numm=0;
                change1();
                xianshi();
程序哪儿处理的不够好
GMT+8, 2024-6-5 19:39 , Processed in 0.028141 second(s), 23 queries , Gzip On.
