查看: 13490|回复: 4
TIM1 产生pwm的问题
发表于 2015-7-13 21:36:46 | 显示全部楼层 |阅读模式
  * @file    main.c
  * @author  fire
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   2aêÔtim1Ëĸöí¨μàêä3ö2»í¬Õ¼¿Õ±èμÄpwm2¨(PA8.PA9.PA10--2¢μ÷êÔ3ö»¥212¨DÎ)
  * @attention
  * êμÑéƽì¨:ò°»e iSO STM32 ¿a·¢°å
  * ÂÛì3    :http://www.firebbs.cn
  * ìÔ±|    :http://firestm32.taobao.com
#include "stm32f10x.h"
#include "bsp_pwm_output.h"
  * @brief  Ö÷oˉêy
  * @param  ÎT
  * @retval ÎT
        //TIM3_PWM_Init();
        //TIM1_PWM_Init();
        TIM1_PWM_Init();
        while (1)
/*以上是main函数*/
/*下面是bsp_pwm_output.c文件*/
  * @file    bsp_pwm_output.c
  * @author  STMicroelectronics
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   tim3êä3öËÄ·pwm bsp
  * @attention
static void TIM1_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
  /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
static void TIM1_Mode_Config(void)
        u16 CCR1_Val = 500;
        u16 CCR2_Val = 375;
        u16 CCR3_Val = 250;
    TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR+1)* 100% = 50%
    TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR+1)* 100% = 37.5%
    TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR+1)* 100% = 25%
    TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR+1)* 100% = 12.5%
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM1, ENABLE);
  TIM_Cmd(TIM1, ENABLE);
         //TIM_Cmd(TIM3, ENABLE);
  void TIM1_PWM_Init(void)
        //TIM3_GPIO_Config();
        //TIM3_Mode_Config();
        TIM1_GPIO_Config();
        TIM1_Mode_Config();
以上代码是根据火哥的例子改的的,编译时,提示TIM3_PWM_Init()没有定义。这是怎么回事。在线等。请求帮忙
 楼主| 发表于 2015-7-13 21:38:43 | 显示全部楼层
..\..\User\main.c(31): warning:  #223-D: function "TIM1_PWM_Init" declared implicitly
 楼主| 发表于 2015-7-13 21:42:25 | 显示全部楼层
有人在吗?请帮帮忙
 楼主| 发表于 2015-7-13 21:49:45 | 显示全部楼层
我找到原因了,在.h文件里也要声明。只是修改完了。发现没有输出波形
 楼主| 发表于 2015-7-14 08:23:20 | 显示全部楼层
还是没人帮忙
GMT+8, 2024-5-6 21:11 , Processed in 0.030296 second(s), 23 queries , Gzip On.
