扫一扫,访问微社区
查看: 781|回复: 1
[F0/F1/F2] 103的TIM1输出CH1与CH2通道的PWM移相了90°,配置的模式是PWM1模式,求大佬解答
发表于 2019-3-14 13:15:56 | 显示全部楼层 |阅读模式
程序附上
void TIM1_PWM_Init(u16 pFreq,u16 psc)
        GPIO_InitTypeDef                                   GPIO_InitStructure;
        TIM_OCInitTypeDef                            TIM_OCInitStructure;                        //输出通道配置
        TIM_BDTRInitTypeDef                   TIM_BDTRInitStructure;                //死区和刹车配置
        TimerPeriod = (SystemFrequency  / pFreq) - 1;                         //自动重装载周期值
        /* ChannelxPulse = DutyCycle * (TIM1_Period - 1) / 100 */
        Channel1Pulse = (u16)((u32)(48  * (TimerPeriod - 1)) / 100 );        //占空比50%
        Channel2Pulse = (u16)((u32)(51  * (TimerPeriod - 1)) / 100 );        //占空比50%
        /* 使能TIM1,GPIOA,GPIOB,GPIOE */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOE, ENABLE);
        /*channel1 ,channel2 -->A.8,A.9*
         *channel1N,channel2N-->B.13,B.14*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14;
  /*  初始化TIM1  */
        TIM_TimeBaseStructure.TIM_Period            = TimerPeriod;//7199;       //设置重装载周期值
        TIM_TimeBaseStructure.TIM_Prescaler         = psc;                            //设置预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision     = 0;                        //时钟分频因子,仅与输入捕获有关(定时器与滤波器的频率比)
        TIM_TimeBaseStructure.TIM_CounterMode       = TIM_CounterMode_Up;//TIM向上计数模式
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;        //重复溢出中断
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);                  //初始化定时器基本配置
        /* Channel_1   TIM_OCMode_PWM1模式 */
        TIM_OCInitStructure.TIM_OCMode       = TIM_OCMode_PWM1;                //在向上计数时,一旦TIMx_CNT<TIMx_CCR1时通道1为有效电平
        TIM_OCInitStructure.TIM_OutputState  = TIM_OutputState_Enable;          //比较输出使能
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;         //PWM互补输出使能
        TIM_OCInitStructure.TIM_Pulse        = Channel1Pulse;//50* 7200 / 100;;                                //占空比 = TIM_Pulse/TIM_Period;
        TIM_OCInitStructure.TIM_OCPolarity   = TIM_OCPolarity_High;             //有效电平为高电平
        TIM_OCInitStructure.TIM_OCNPolarity  = TIM_OCNPolarity_High;           //互补PWM极性
        TIM_OCInitStructure.TIM_OCIdleState  = TIM_OCIdleState_Set;                   //输出空闲状态
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;          //PWM互补输出空闲状态
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);                                //根据指定的参数初始化外设TIM1 OC1
        /* Channel_2          TIM_OCMode_PWM1模式 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;              //在向上计数时,一旦TIMx_CNT>TIMx_CCR1时通道1为有效电平
        TIM_OCInitStructure.TIM_Pulse  = Channel2Pulse;//50* 7200 / 100;;                       //占空比 = TIM_Pulse/TIM_Period;
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);                       //根据指定的参数初始化外设TIM1 OC2
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);          //使能TIM3在CCR1上的预装载寄存器
        TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);          //使能TIM3在CCR2上的预装载寄存器
        /*死区和刹车功能配置*/
        TIM_BDTRInitStructure.TIM_OSSRState       = TIM_OSSRState_Enable;
        TIM_BDTRInitStructure.TIM_OSSIState       = TIM_OSSIState_Enable;
        TIM_BDTRInitStructure.TIM_LOCKLevel       = TIM_LOCKLevel_1;
        TIM_BDTRInitStructure.TIM_DeadTime        = 0X18;                //设置TIM1_BDTR的DTG[7:0]
        TIM_BDTRInitStructure.TIM_Break           = TIM_Break_Disable;
        TIM_BDTRInitStructure.TIM_BreakPolarity   = TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
        TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
        TIM_Cmd(TIM1, DISABLE);                                                 //使能TIM1
        TIM_CtrlPWMOutputs(TIM1,DISABLE);        //PWM输出使能
 楼主| 发表于 2019-3-14 13:26:01 | 显示全部楼层
大佬们帮帮忙啊
野火电子公众号
GMT+8, 2019-5-19 16:28 , Processed in 0.048436 second(s), 30 queries , Gzip On.
© 2014-2016 www.firebbs.cn
