扫一扫,访问微社区
查看: 110|回复: 7
[F4] I2C端口初始化后就BUSY,请高手指教
发表于 2019-6-9 16:39:18 | 显示全部楼层 |阅读模式
手里有一个STM32F411的板子,最近被I2C搞崩溃了,I2C1接口正常,初始化没有问题,但是I2C3不知道为什么,同样的代码,只要一初始化,SDA马上拉低,不进行初始化,SCL和SDA都是高电平,只要进行完初始化,SDA就会被拉低。关键是同样的代码,用在I2C1接口就是正常的。实在找不到原因了,请高手给指导一下,万分感谢!下面是初始化代码:
void STM32_I2C3_Config(void)
        /*开I2C3时钟*/
        //I2C外设时钟
        RCC_APB1PeriphClockCmd(STM32_I2C3_CLK,ENABLE);
        //I2C3_GPIO时钟
        RCC_AHB1PeriphClockCmd(STM32_I2C3_SCL_CLK | STM32_I2C3_SDA_CLK,ENABLE);
        /*GPIO引脚连接到I2C3外设*/
        //SCL
        GPIO_PinAFConfig(STM32_I2C3_SCL_GPIO,STM32_I2C3_SCL_SOURCE,STM32_I2C3_SCL_AF);
        //SDA
        GPIO_PinAFConfig(STM32_I2C3_SDA_GPIO,STM32_I2C3_SDA_SOURCE,STM32_I2C3_SDA_AF);
        /*定义初始化结构体*/
        I2C_InitTypeDef I2C_InitStruct;
        /*配置GPIO初始化结构体成员*/
        //SCL配置
        GPIO_InitStruct.GPIO_Pin = STM32_I2C3_SCL_PIN;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
        GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
        /*调用GPIO初始化函数,把配置好的结构体成员的参数写入到寄存器*/
        GPIO_Init(STM32_I2C3_SCL_GPIO,&GPIO_InitStruct);
        //SDA配置
        GPIO_InitStruct.GPIO_Pin = STM32_I2C3_SDA_PIN;
        //GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
        //GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
        //GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
        //GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(STM32_I2C3_SDA_GPIO,&GPIO_InitStruct);
        /*I2C寄存器恢复初始值*/
        I2C_DeInit(STM32_I2C3);
        /*I2C结构体配置*/
        I2C_InitStruct.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStruct.I2C_ClockSpeed = STM32_I2C3_Speed;
        I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStruct.I2C_OwnAddress1 = STM32_I2C3_OwnAddress;
        /*调用I2C初始化函数,把配置好的结构体成员的参数写入到寄存器*/
        I2C_Init(STM32_I2C3,&I2C_InitStruct);
        //使能I2C
        I2C_Cmd(STM32_I2C3,ENABLE);
发表于 2019-6-9 20:45:32 | 显示全部楼层
帮顶,用模拟吧
 楼主| 发表于 2019-6-9 22:04:09 | 显示全部楼层
WishWish 发表于 2019-6-9 20:45
帮顶,用模拟吧
关键初始化都不行,不至于这么严重吧,不甘心啊
发表于 2019-6-9 22:56:10 | 显示全部楼层
话说那个deinit函数干嘛用的?然后是不是外部被拉低了?
发表于 2019-6-10 08:47:08 | 显示全部楼层
我两个月前,同样的平台、代码也出现了类似的现象。
刚开始初始化IO口跳变正常。初始化输入不正常,(后来发现软件初始化配置的类型不对应)。修改后就可以正常做IO高低电平检测了。
最后再回归到硬件I2C,最终发现从设备不正常,导致初始化硬件I2C就立马被拉低。修改从设备硬件解决问题。
 楼主| 发表于 4 天前 | 显示全部楼层
那个函数是设置iic的寄存器为初始值,没有这局也是不行,都是被拉低
刚开始初始化IO口跳变正常。初始化输入不正常,(后来 ...
我的情况是,在不进行初始化,总线的状态是正常的,是不是证明从设备没有问题?只要进行初始化就不行了
发表于 3 天前 | 显示全部楼层
你自己再理解我的表达。首先改确认主设备IO是否正常(IO输出模式正常可控),然后再确认线路是否正常(测量电平特性),最后在确认从设备是否正常(回归I2C通信的配置模式,多个方式测试验证)。
野火电子公众号
GMT+8, 2019-6-18 19:08 , Processed in 0.049226 second(s), 33 queries , Gzip On.
© 2014-2016 www.firebbs.cn
