扫一扫,访问微社区
查看: 478|回复: 9
[下载器] 读取按键代码
发表于 2019-6-12 09:08:31 | 显示全部楼层 |阅读模式
[C] 纯文本查看 复制代码
#include "stm32f10x.h"
#include "key.h"
#include "delay.h"
u32 Keycode;
u32 KEY_Trg;
u32 KEY_Cont=0;
  * [url=home.php?mod=space&uid=41770]@brief[/url]  初始化GPIOB的引脚11到15,分别对应按键1到5
  * @param  无
  * @retval 无
void KEY_Init(void)
	GPIO_InitTypeDef GPIOStructure;
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); 																//使能GPIOB
	GPIOStructure.GPIO_Mode = GPIO_Mode_IPU;																							//上拉输入
	GPIOStructure.GPIO_Pin =GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;	//KEY1-5用到的GPIO口为GPIOB11-15
	GPIOStructure.GPIO_Speed = GPIO_Speed_10MHz;
	GPIO_Init(GPIOB, &GPIOStructure);
static uint32_t Change_GPIOCode(void)
	u32 GPIO_Data;
	GPIO_Data=(((GPIOB->IDR)>>11)&0xffff)|(~(KEY1BIT+KEY2BIT+KEY3BIT+KEY4BIT+KEY5BIT));
	return GPIO_Data;
unsigned char KEY_Read(void)
	u32 ReadData = Change_GPIOCode()^0XFFFFFFFF;     // 异或后,ReadData的位5-31均为0,
	KEY_Trg = ReadData & (ReadData ^ KEY_Cont);      // 2
	KEY_Cont = ReadData;
	if(KEY_Cont)
			delay_ms(10);
			ReadData = Change_GPIOCode()^0XFFFFFFFF;   // 1
			if(KEY_Cont)
				switch(KEY_Cont)
					case K_1:{Keycode = K_1_S; break;}
					case K_2:{Keycode = K_2_S; break;}
					case K_3:{Keycode = K_3_S; break;}
					case K_4:{Keycode = K_4_S; break;}
					case K_5:{Keycode = K_5_S; break;}
					default:{Keycode = K_NO; break;}
	return Keycode;
void KEY_EXIT(void)
	if(Keycode != K_NO)
		Keycode = K_NO;
大佬救救我,unsigned char KEY_Read(void),static uint32_t Change_GPIOCode(void)这两个函数干嘛用的?
(~(KEY1BIT+KEY2BIT+KEY3BIT+KEY4BIT+KEY5BIT))这句代码有什么用,前人没打备注完全看不懂啊。
[C] 纯文本查看 复制代码
#ifndef __key_H
#define __key_H
#define YES	  1
#define NO	  0
#define T_10mS	((u32)10)
#define T_1S	((u32)1000)
#define T_330mS	((u32)330)
#define KEY1BIT GPIO_Pin_0
#define KEY2BIT GPIO_Pin_1
#define KEY3BIT GPIO_Pin_2
#define KEY4BIT GPIO_Pin_3
#define KEY5BIT GPIO_Pin_4
////////原始码值///////////////
#define K_1		KEY1BIT
#define K_2		KEY2BIT
#define K_3		KEY3BIT
#define K_4		KEY4BIT
#define K_5		KEY5BIT
////////码值重映射////////////
#define K_1_S		0X01
#define K_2_S		0X02
#define K_3_S		0X03
#define K_4_S		0X04
#define K_5_S		0X05
#define K_1_L		0X0B
#define K_2_L		0X0C
#define K_3_L		0X0D
#define K_4_L		0X0E
#define K_5_L		0X0F
#define K_NO		0X00000000
extern u32 KEY_Trg;
extern u32 KEY_Cont;
extern u32 Keycode;
void KEY_Init(void);
unsigned char KEY_Read(void);
void KEY_EXIT(void);
#endif
发表于 2019-6-12 10:04:17 | 显示全部楼层
Change_GPIOCode  里面用 GPIOB->IDR 读取 变化的了GPIO状态值?然后KEY_Read里面有再用一次但感觉又不像消抖的意思,看晕了……
 楼主| 发表于 2019-6-12 10:57:11 | 显示全部楼层
WishWish 发表于 2019-6-12 10:04
Change_GPIOCode  里面用 GPIOB->IDR 读取 变化的了GPIO状态值?然后KEY_Read里面有再用一次但感觉又不像消 ...
他的意思貌似是:因为按键原来接在pin11到pin15,change_GPIOCode()是将pin11-pin15的值右移到pin0-pin4.
然后KEY_Read函数返回了1、2、3、4、5代表5个按键,就不在用引脚表示5个按键了,后面要用到这些返回值做运算应该。
GPIO_Data=(((GPIOB->IDR)>>11)&0xffff)|(~(KEY1BIT+KEY2BIT+KEY3BIT+KEY4BIT+KEY5BIT));这句代码后面的(~(KEY1BIT+KEY2BIT+KEY3BIT+KEY4BIT+KEY5BIT))什么意思?
发表于 2019-6-12 11:30:18 | 显示全部楼层
wx_qI5uA9eD 发表于 2019-6-12 10:57
他的意思貌似是:因为按键原来接在pin11到pin15,change_GPIOCode()是将pin11-pin15的值右移到pin0-pin4. ...
0X1F取反就是相当于~(GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4) 应该是为了获取哪些按键按下了吧
 楼主| 发表于 2019-6-12 12:02:00 | 显示全部楼层
非谢家之宝树 发表于 2019-6-12 11:30
0X1F取反就是相当于~(GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4) 应该是为了获取哪些按键 ...
GPIO_pin0-4默认为1吗?我记得好像是默认为0
 楼主| 发表于 2019-6-12 12:03:08 | 显示全部楼层
GPIO_Pin_0、GPIO_Pin_1、GPIO_Pin_2、GPIO_Pin_3、GPIO_Pin_4这四个引脚没有配置,默认值是多少?
发表于 2019-6-12 13:11:14 | 显示全部楼层
这个在st的库里有定义,可以看看就知道了
[C] 纯文本查看 复制代码
#define GPIO_Pin_0                 ((uint16_t)0x0001)  /*!< Pin 0 selected */
#define GPIO_Pin_1                 ((uint16_t)0x0002)  /*!< Pin 1 selected */
#define GPIO_Pin_2                 ((uint16_t)0x0004)  /*!< Pin 2 selected */
#define GPIO_Pin_3                 ((uint16_t)0x0008)  /*!< Pin 3 selected */
#define GPIO_Pin_4                 ((uint16_t)0x0010)  /*!< Pin 4 selected */
#define GPIO_Pin_5                 ((uint16_t)0x0020)  /*!< Pin 5 selected */
#define GPIO_Pin_6                 ((uint16_t)0x0040)  /*!< Pin 6 selected */
#define GPIO_Pin_7                 ((uint16_t)0x0080)  /*!< Pin 7 selected */
#define GPIO_Pin_8                 ((uint16_t)0x0100)  /*!< Pin 8 selected */
#define GPIO_Pin_9                 ((uint16_t)0x0200)  /*!< Pin 9 selected */
#define GPIO_Pin_10                ((uint16_t)0x0400)  /*!< Pin 10 selected */
#define GPIO_Pin_11                ((uint16_t)0x0800)  /*!< Pin 11 selected */
#define GPIO_Pin_12                ((uint16_t)0x1000)  /*!< Pin 12 selected */
#define GPIO_Pin_13                ((uint16_t)0x2000)  /*!< Pin 13 selected */
#define GPIO_Pin_14                ((uint16_t)0x4000)  /*!< Pin 14 selected */
#define GPIO_Pin_15                ((uint16_t)0x8000)  /*!< Pin 15 selected */
#define GPIO_Pin_All               ((uint16_t)0xFFFF)  /*!< All pins selected */
 楼主| 发表于 2019-6-12 16:50:29 | 显示全部楼层
非谢家之宝树 发表于 2019-6-12 13:11
这个在st的库里有定义,可以看看就知道了[mw_shl_code=c,true]#define GPIO_Pin_0                 ((uin ...
谢谢大神,问题已解决。万分感谢
发表于 2019-7-21 11:22:22 | 显示全部楼层
wx_qI5uA9eD 发表于 2019-6-12 16:50
谢谢大神,问题已解决。万分感谢
兄弟,我还是没搞懂,能解释下吗,万分感谢
 楼主| 发表于 2019-8-1 20:55:55 | 显示全部楼层
[C] 纯文本查看 复制代码
  *		与1异或相当于取反,与0异或相当于不变。
	*		第一种情况:没有按键按下的时候,GPIO_Data为0XFFFFFFFF,ReadData经过取反后自然是0X0了。KEY_Trg = 0&(0^0) = 0X0。(初始状态下Cont为0)
	*								KEY_Cont = ReadData = 0。结果就是ReadData = 0;KEY_Trg = 0;KEY_Cont = 0;即没有按键按下。
	*		第二种情况:Key1第一次按下,GPIO_Data为0XFFFFFFFE,ReadData经过取反后自然是0X01了。KEY_Trg = 0X01&(0X01^0) = 0X01。这是第一次按下Cont
	*								仍为上次的值。KEY_Cont = ReadData = 0X01。所以ReadData = 0X01;KEY_Trg = 0X01;KEY_Cont = 0X01。
	*		第三种情况:key1长按着不放,GPIO_Data为0XFFFFFFFE,ReadData经过取反后自然是0X01了。KEY_Trg = 0X01&(0X01^0X01) = 0X0。Cont是上次按下的值
	*								并没有对Cont清零的语句。所以ReadData = 0X01;KEY_Trg = 0X0;KEY_Cont = 0X01。
	*								只要按键按着不放,一直执行这个函数,ReadData永远不变,KEY_Cont永远为上次值,即0X01,KEY_Trg永远为0X0。
	*		第四种情况:key1按键松开,GPIO_Data为0XFFFFFFFF,ReadData经过取反后自然是0X0了。KEY_Trg = 0 &(0^0X1) = 0X0,KEY_Cont = ReadData = 0。
	*								结果就是ReadData = 0;KEY_Trg = 0;KEY_Cont = 0;即没有按键按下。
	*		总结		 :Trg就是跳变,只要按键按下,电平从1到0跳变了,那么KEY_Trg对应的按键位置1。KEY_Trg的值每次按下只会出现一次(只会在情况二出现一次),
	*								然后立马被清除。不需要其它判断条件。
  * @brief  读取五个按键的状态,并返回对应的按键编码。
  * @param  无
  * @retval Keycode:按键对应编号,
野火电子公众号
GMT+8, 2019-9-20 19:54 , Processed in 0.037322 second(s), 26 queries , Gzip On.
© 2014-2016 www.firebbs.cn
