查看: 15374|回复: 13
stm32f103vet6的spi3配置问题
发表于 2015-12-20 12:11:36 | 显示全部楼层 |阅读模式
  * @file    bsp_led.c
  * @author  fire
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   ledó|ó?oˉêy?ó?ú
  * @attention
  * êμ?é??ì¨:ò°?e iSO-MINI STM32 ?a·¢°?
  * ??ì3    :http://www.firebbs.cn
  * ì?±|    :http://firestm32.taobao.com
#include "bsp_led.h"
#include "stm32f10x_spi.h"
  * @brief  3?ê??ˉ????LEDμ?IO
  * @param  ?T
  * @retval ?T
void LED_GPIO_Config(void)
                /*?¨ò?ò???GPIO_InitTypeDefààDíμ??á11ì?*/
                /*?a??LEDμ?íaéèê±?ó*/
                RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);
                /*????òa????μ?GPIOBòy??*/
//                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
//          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
//          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_9;
                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
                /*????òa????μ?òy??*/
********PBòy??????************************************
********PB3£?PB4**************************************
//                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4;
//                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
//                GPIO_Init(GPIOB, &GPIO_InitStructure);
void SPI3_Init()
   SPI_InitTypeDef  SPI_InitStructure;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
******AFIO****************
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
         GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
//  AFIO->MAPR =(AFIO->MAPR|0x02000000)&0xFAFFFFFF;
******SPI3_NSS*************
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
******SPI3_CLK*************
******SPI3_DIN*************
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
******SPI3_DOUT************
         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
   SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
   SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
   SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
   SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
   SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
   SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
   SPI_InitStructure.SPI_CRCPolynomial = 7;
   SPI_Init(SPI3, &SPI_InitStructure);
         ******ENABLE SPII3******
         SPI_Cmd(SPI3, ENABLE);
这是我配置的,请大神看看有什么问题
发表于 2015-12-20 13:04:24 | 显示全部楼层
您的问题是什么呢?呵呵
发表于 2015-12-20 13:31:19 | 显示全部楼层
qduwg 发表于 2015-12-20 13:04
您的问题是什么呢?呵呵
他的spi3没调通
发表于 2015-12-20 13:40:21 | 显示全部楼层
我发程序是已经调通的了  都是103   只不过我用的是encc28j60  你要是用其他的比如flash 只看初始化部分就可以了 在spi.c里
你这个简单看了一下 没用到PB5吗
发表于 2015-12-20 13:46:40 | 显示全部楼层
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;   //可以改成SPI_CPOL_Low
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;//可以改成SPI_CPHA_1Edge
试一试,注意看手册!!
发表于 2015-12-20 13:47:05 | 显示全部楼层
试一试,注意看手册!!
 楼主| 发表于 2015-12-20 14:11:10 | 显示全部楼层
SPI_InitStructure.SPI_CPHA = S ...
我的spi3_clk没有数据输出啊
 楼主| 发表于 2015-12-20 14:12:18 | 显示全部楼层
您的问题是什么呢?呵呵
我用示波器看只有PA15有数据输出而时钟线和数据输出线没有输出
 楼主| 发表于 2015-12-20 14:26:28 | 显示全部楼层
andyzhao 发表于 2015-12-20 13:40
我发程序是已经调通的了  都是103   只不过我用的是encc28j60  你要是用其他的比如flash 只看初始化部分就 ...
用到PA15,PB3,PB4,PB5可是只是有片选信号 时钟信号和数据输出没有信号啊
发表于 2015-12-20 15:36:41 | 显示全部楼层
没有看到你初始化PB5啊
另外是否失能JTAG映射成普通IO口
 楼主| 发表于 2015-12-20 16:48:44 | 显示全部楼层
andyzhao 发表于 2015-12-20 15:36
没有看到你初始化PB5啊
另外是否失能JTAG映射成普通IO口
更改改了  也不行
 楼主| 发表于 2015-12-20 16:50:53 | 显示全部楼层
没有看到你初始化PB5啊
另外是否失能JTAG映射成普通IO口
只要我加上那两句释放JTAG的程序就能用spi3吗?
发表于 2015-12-20 16:58:45 | 显示全部楼层
是滴 啊 正确配置spi3 然后RCC_APB2Periph_AFIO和失能jtag 就完事好了
 楼主| 发表于 2015-12-20 17:20:38 | 显示全部楼层
可是我的时钟线还是没有信号啊
GMT+8, 2024-11-22 22:45 , Processed in 0.034898 second(s), 23 queries , Gzip On.
