查看: 14446|回复: 3
定义了三个外部中断,却只有一个能进,求大神指导,外部输入信号没问题
发表于 2015-12-23 14:30:17 | 显示全部楼层 |阅读模式
遇到的问题是 定义了三个外部中断,但是只有PE.7对应的中断能进,其他两个不行,求大神指导啊
exti.c文件中的代码
#include "exti.h"
static void NVIC_Configuration(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);//°ÑNVICÖD¶ÏóÅÏ輶·Ö×ééèÖÃÎaμúò»×é
        NVIC_InitStructure.NVIC_IRQChannel=EXTI9_5_IRQn;//±íê¾òaÅäÖÃμÄλEXTIμú5~9ÏßμÄÖD¶ÏÏòá¿
  NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;//ê1ÄüÏàó|ÖD¶ÏÏòá¿μÄÖD¶ÏÏìó|
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;//ÇàÕ¼óÅÏ輶
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;//Ïìó|óÅÏ輶
void EXTI_GPIOE_Config(void) // PE[5|6|7]
        EXTI_InitTypeDef EXTI_InitStructure;
        //ê1ÄüEXTIx(PE5)μÄê±Öóoíμú¶t1|ÄüAFIOê±Öó
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,ENABLE);
        NVIC_Configuration();//
        /*¸ø½á11ìå±äá¿GPIO_InitStructure3õê¼»ˉ*/
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPD;//éÏà-êäèëÄ£ê½
        GPIO_Init(GPIOE,&GPIO_InitStructure);
  /*EXTIÖD¶ÏÏß¼°1¤×÷Ä£ê½ÅäÖÃ*/
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOE,GPIO_PinSource5 | GPIO_PinSource6 | GPIO_PinSource7);//ê1óÃGPIO(PE[5|6|7]) ×÷Îaía2¿ÖD¶Ïêäèëòy½Å
        //EXTI_InitStructure.EXTI_Line=EXTI_Line5;//½«DÅożì2aòy½&#197E5ᬽóμ½EXTI_Line5
        EXTI_InitStructure.EXTI_Line=EXTI_Line5 | EXTI_Line6 | EXTI_Line7;//½«DÅożì2aòy½&#197E5¡¢6¡¢7ᬽóμ½EXTI_Line5¡¢6¡¢7
        EXTI_InitStructure.EXTI_LineCmd=ENABLE;//ê1Äü
        EXTI_InitStructure.EXTI_Mode=EXTI_Mode_Interrupt;//éèÖÃÎaÖD¶ÏÄ£ê½
        EXTI_InitStructure.EXTI_Trigger=EXTI_Trigger_Falling;//ϽμÑØÖD¶Ï
        EXTI_Init(&EXTI_InitStructure);//½«3õê¼»ˉ½á11ìåμÄ2ÎêyD′èë¼Ä′æÆ÷
中断代码
#include "stm32f10x_it.h"
#include "relay.h"
#include "led.h"
void EXTI9_5_IRQHandler()
        GPIO_SetBits(GPIOD,GPIO_Pin_13);//D5áá
        GPIO_SetBits(GPIOG,GPIO_Pin_14);//D2áá
        if(EXTI_GetITStatus(EXTI_Line5)!=RESET)//è·±£êÇ·ñ2úéúáËEXTI Line5 ÖD¶Ï£¨¼′±ê־λêÇ·ñÖÃ룩
                GPIO_ResetBits(GPIOG,GPIO_Pin_14);//D2Ãe
                GPIO_ResetBits(GPIOD,GPIO_Pin_13);//D5Ãe
                GPIO_SetBits(GPIOB,GPIO_Pin_5);
                EXTI_ClearITPendingBit(EXTI_Line5);        //Çå3yÖD¶Ï±ê־λ
        if(EXTI_GetITStatus(EXTI_Line6)!=RESET)//è·±£êÇ·ñ2úéúáËEXTI Line6 ÖD¶Ï£¨¼′±ê־λêÇ·ñÖÃ룩
                GPIO_SetBits(GPIOE,GPIO_Pin_5);
    EXTI_ClearITPendingBit(EXTI_Line6);        //Çå3yÖD¶Ï±ê־λ
        if(EXTI_GetITStatus(EXTI_Line7)!=RESET)//è·±£êÇ·ñ2úéúáËEXTI Line7 ÖD¶Ï£¨¼′±ê־λêÇ·ñÖÃ룩//R
//                 GPIO_SetBits(GPIOG,GPIO_Pin_14);//D2áá
//                GPIO_ResetBits(GPIOG,GPIO_Pin_14);//D2Ãe
    GPIO_ResetBits(GPIOB,GPIO_Pin_5);
                GPIO_ResetBits(GPIOE,GPIO_Pin_5);
                EXTI_ClearITPendingBit(EXTI_Line7);        //Çå3yÖD¶Ï±ê־λ
外部中断输入的3个引脚
外部中断输入的3个引脚
发表于 2015-12-23 16:02:49 | 显示全部楼层
EXTI_InitStructure.EXTI_Line=EXTI_Line5 | EXTI_Line6 | EXTI_Line7;//½«DÅożì2aòy½ÅE5¡¢6¡¢7ᬽóμ½EXTI_Line5¡¢6¡¢7
每个都分开配置,不要使用或运行配置
发表于 2015-12-23 16:04:39 | 显示全部楼层
一条线一条线地配置,看看只PE5或只配置PE6时能不能进,
搞定了再把三个同时合起来测试
 楼主| 发表于 2015-12-23 16:57:37 | 显示全部楼层
谢谢,我试试
GMT+8, 2024-11-23 19:26 , Processed in 0.030707 second(s), 26 queries , Gzip On.
