查看: 12274|回复: 1
ADC快速交叉模式
发表于 2016-1-3 14:20:12 | 显示全部楼层 |阅读模式
因为我采集的频率要大于1.4MHz,所以考虑使用ADC快速交叉模式,不知道可不可行?
如果可行,请帮我看看adc交叉模式的代码对不对
static void ADC12_GPIO_Config(void)
        /* Enable DMA clock */
        /* Enable ADC1 and GPIOC clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 |RCC_APB2Periph_ADC2 | RCC_APB2Periph_GPIOA, ENABLE);
                /*ÅäÖÃADCê±Öó£¬ÎaPCLK2μÄ6·ÖÆ죬¼′12MHz*/
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);
        /* Configure PA.01  as analog input */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_Init(GPIOA, &GPIO_InitStructure);                                // PA1,êäèëê±2»óÃéèÖÃËùÂê
  * @brief  ÅäÖÃADC12μÄ1¤×÷Ä£ê½ÎaMDAÄ£ê½
  * @param  ÎT
  * @retval ÎT
static void ADC12_Mode_Config(void)
        /* DMA channel1 configuration */
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;                                 //ADCμØÖ·
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //Äú′æμØÖ·
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 1;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //íaéèμØÖ·1춨
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;                                  //Äú′æμØÖ·1춨
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //°ë×Ö
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Ñ-»·′«êä
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        /* Enable DMA channel1 */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        /* ADC1 configuration ------------------------------------------*/
        ADC_InitStructure.ADC_Mode = ADC_Mode_FastInterl ;                        //ADC1oíADC2 1¤×÷Ôú¿ìËù½»2æÄ£ê½
        ADC_InitStructure.ADC_ScanConvMode = DISABLE; ;                                          //½ûÖ1é¨Ãèģ꽣¬é¨ÃèÄ£ê½óÃóú¶àí¨μà2é¼ˉ
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                        //¿aÆôá¬Dø×a»»Ä£ê½£¬¼′2»í£μؽøDDADC×a»»
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //2»ê1óÃía2¿′¥·¢×a»»
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //2é¼ˉêy¾Yóò¶ÔÆë
        ADC_InitStructure.ADC_NbrOfChannel = 1;        //òa×a»»μÄí¨μàêyÄ¿1
        /* ADC1 regular channels configuration */
        /*ÅäÖÃADC1μÄí¨μà11Îa55.        5¸ö2éÑùÖüÆú£¬DòáDÎa1 */
        ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_1Cycles5);
//        ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 2, ADC_SampleTime_55Cycles5);
        /* Enable ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
         /* ADC2 configuration ------------------------------------------------------*/
        ADC_Init(ADC2, &ADC_InitStructure);
  /* Enable ADC2 */
  ADC_Cmd(ADC2, ENABLE);
         /* ADC2 regular channels configuration */
        /*ÅäÖÃADC2μÄí¨μà11Îa55.        5¸ö2éÑùÖüÆú£¬DòáDÎa1 */
        ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 1, ADC_SampleTime_1Cycles5);
        /*¸′λD£×¼¼Ä′æÆ÷ */
        ADC_ResetCalibration(ADC1);
        /*μè′yD£×¼¼Ä′æÆ÷¸′λíê3é */
        while(ADC_GetResetCalibrationStatus(ADC1));
        /* ADCD£×¼ */
        ADC_StartCalibration(ADC1);
        /* μè′yD£×¼íê3é*/
        while(ADC_GetCalibrationStatus(ADC1));
        /* óéóúûóD2éóÃía2¿′¥·¢£¬ËùòÔê1óÃèí¼t′¥·¢ADC×a»» */
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  /* Enable ADC2 reset calibration register */
  ADC_ResetCalibration(ADC2);
  /* Check the end of ADC2 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC2));
  /* Start ADC2 calibration */
  ADC_StartCalibration(ADC2);
  /* Check the end of ADC2 calibration */
  while(ADC_GetCalibrationStatus(ADC2));
  /* Start ADC1 Software Conversion */
        /* Test on DMA1 channel1 transfer complete flag */
  while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
  /* Clear DMA1 channel1 transfer complete flag */
  DMA_ClearFlag(DMA1_FLAG_TC1);
发表于 2016-1-3 21:08:39 | 显示全部楼层
可参考F4的adc章节:
http://www.firebbs.cn/thread-10568-1-1.html
GMT+8, 2024-11-24 04:32 , Processed in 0.028245 second(s), 23 queries , Gzip On.
