高中生
最后登录1970-1-1
在线时间 小时
注册时间2015-10-23
将mini板例程中的SPI-FLASH实验代码的 SPI1 改为 SPI2 后 ,为什么读取FLASH的ID为0xFF?是下面的配置有问题吗?
void SPI_FLASH_Init(void)
SPI_InitTypeDef SPI_InitStructure;
/* Enable SPI1 and GPIO clocks */
/*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
/*!< SPI_FLASH_SPI Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
/*!< Configure SPI_FLASH_SPI pins: SCK */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
/*!< Configure SPI_FLASH_SPI pins: MISO */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
/*!< Configure SPI_FLASH_SPI pins: MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
// GPIO_SetBits(GPIOB,GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15);
/*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
/* Deselect the FLASH: Chip Select high */
SPI_FLASH_CS_HIGH();
/* SPI1 configuration */
// W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
// Data on the DO and DIO pins are clocked out on the falling edge of CLK.
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
SPI_Cmd(SPI2, ENABLE);
SPI_FLASH_SendByte(0xff);
