高中生
最后登录1970-1-1
在线时间 小时
注册时间2015-5-6
楼主 |
发表于 2016-1-6 19:10:10
显示全部楼层
解码函数MP3Decode我仿真跟踪发现没有看到有出错PCM数据的地方
* Function: MP3Decode
* Description: decode one frame of MP3 data
* Inputs: valid MP3 decoder instance pointer (HMP3Decoder)
* double pointer to buffer of MP3 data (containing headers + mainData)
* number of valid bytes remaining in inbuf
* pointer to outbuf, big enough to hold one frame of decoded PCM samples
* flag indicating whether MP3 data is normal MPEG format (useSize = 0)
* or reformatted as "self-contained" frames (useSize = 1)
* Outputs: PCM data in outbuf, interleaved LRLRLR... if stereo
* number of output samples = nGrans * nGranSamps * nChans
* updated inbuf pointer, updated bytesLeft
* Return: error code, defined in mp3dec.h (0 means no error, < 0 means error)
* Notes: switching useSize on and off between frames in the same stream
* is not supported (bit reservoir is not maintained if useSize on)
int MP3Decode(HMP3Decoder hMP3Decoder, unsigned char **inbuf, int *bytesLeft, short *outbuf, int useSize)
int offset, bitOffset, mainBits, gr, ch, fhBytes, siBytes, freeFrameBytes;
int prevBitOffset, sfBlockBits, huffBlockBits;
unsigned char *mainPtr;
MP3DecInfo *mp3DecInfo = (MP3DecInfo *)hMP3Decoder;
if (!mp3DecInfo)
return ERR_MP3_NULL_POINTER;
/* unpack frame header */ // 解析帧包头
fhBytes = UnpackFrameHeader(mp3DecInfo, *inbuf);
if (fhBytes < 0)
return ERR_MP3_INVALID_FRAMEHEADER; /* don't clear outbuf since we don't know size (failed to parse header) */ //不知道帧头无法解析 //
*inbuf += fhBytes;
/* unpack side info */
siBytes = UnpackSideInfo(mp3DecInfo, *inbuf);
if (siBytes < 0)
MP3ClearBadFrame(mp3DecInfo, outbuf);
return ERR_MP3_INVALID_SIDEINFO;
*inbuf += siBytes;
*bytesLeft -= (fhBytes + siBytes);
/* if free mode, need to calculate bitrate and nSlots manually, based on frame size */
if (mp3DecInfo->bitrate == 0 || mp3DecInfo->freeBitrateFlag)
if (!mp3DecInfo->freeBitrateFlag)
/* first time through, need to scan for next sync word and figure out frame size */
mp3DecInfo->freeBitrateFlag = 1;
mp3DecInfo->freeBitrateSlots = MP3FindFreeSync(*inbuf, *inbuf - fhBytes - siBytes, *bytesLeft);
if (mp3DecInfo->freeBitrateSlots < 0)
return ERR_MP3_FREE_BITRATE_SYNC;
freeFrameBytes = mp3DecInfo->freeBitrateSlots + fhBytes + siBytes;
mp3DecInfo->bitrate = (freeFrameBytes * mp3DecInfo->samprate * 8) / (mp3DecInfo->nGrans * mp3DecInfo->nGranSamps);
mp3DecInfo->nSlots = mp3DecInfo->freeBitrateSlots + CheckPadBit(mp3DecInfo); /* add pad byte, if required */
/* useSize != 0 means we're getting reformatted (RTP) packets (see RFC 3119)
* - calling function assembles "self-contained" MP3 frames by shifting any main_data
* from the bit reservoir (in previous frames) to AFTER the sync word and side info
* - calling function should set mainDataBegin to 0, and tell us exactly how large this
* frame is (in bytesLeft)
if (useSize)
mp3DecInfo->nSlots = *bytesLeft;
if (mp3DecInfo->mainDataBegin != 0 || mp3DecInfo->nSlots <= 0)
/* error - non self-contained frame, or missing frame (size <= 0), could do loss concealment here */
/* can operate in-place on reformatted frames */
mp3DecInfo->mainDataBytes = mp3DecInfo->nSlots;
mainPtr = *inbuf;
*inbuf += mp3DecInfo->nSlots;
*bytesLeft -= (mp3DecInfo->nSlots);
/* out of data - assume last or truncated frame */
if (mp3DecInfo->nSlots > *bytesLeft)
return ERR_MP3_INDATA_UNDERFLOW;
/* fill main data buffer with enough new data for this frame */
if (mp3DecInfo->mainDataBytes >= mp3DecInfo->mainDataBegin)
/* adequate "old" main data available (i.e. bit reservoir) */
memmove(mp3DecInfo->mainBuf, mp3DecInfo->mainBuf + mp3DecInfo->mainDataBytes - mp3DecInfo->mainDataBegin, mp3DecInfo->mainDataBegin);
memcpy(mp3DecInfo->mainBuf + mp3DecInfo->mainDataBegin, *inbuf, mp3DecInfo->nSlots);
mp3DecInfo->mainDataBytes = mp3DecInfo->mainDataBegin + mp3DecInfo->nSlots;
mainPtr = mp3DecInfo->mainBuf;
/* not enough data in bit reservoir from previous frames (perhaps starting in middle of file) */
memcpy(mp3DecInfo->mainBuf + mp3DecInfo->mainDataBytes, *inbuf, mp3DecInfo->nSlots);
mp3DecInfo->mainDataBytes += mp3DecInfo->nSlots;
return ERR_MP3_MAINDATA_UNDERFLOW;
bitOffset = 0;
mainBits = mp3DecInfo->mainDataBytes * 8;
/* decode one complete frame */
for (gr = 0; gr < mp3DecInfo->nGrans; gr++)
for (ch = 0; ch < mp3DecInfo->nChans; ch++)
/* unpack scale factors and compute size of scale factor block */
prevBitOffset = bitOffset;
offset = UnpackScaleFactors(mp3DecInfo, mainPtr, &bitOffset, mainBits, gr, ch);
sfBlockBits = 8*offset - prevBitOffset + bitOffset;
huffBlockBits = mp3DecInfo->part23Length[gr][ch] - sfBlockBits;
mainPtr += offset;
mainBits -= sfBlockBits;
if (offset < 0 || mainBits < huffBlockBits)
return ERR_MP3_INVALID_SCALEFACT;
/* decode Huffman code words */
offset = DecodeHuffman(mp3DecInfo, mainPtr, &bitOffset, huffBlockBits, gr, ch);
if (offset < 0)
return ERR_MP3_INVALID_HUFFCODES;
mainPtr += offset;
mainBits -= (8*offset - prevBitOffset + bitOffset);
/* dequantize coefficients, decode stereo, reorder short blocks */
if (Dequantize(mp3DecInfo, gr) < 0)
return ERR_MP3_INVALID_DEQUANTIZE;
/* alias reduction, inverse MDCT, overlap-add, frequency inversion */
if (IMDCT(mp3DecInfo, gr, ch) < 0)
return ERR_MP3_INVALID_IMDCT;
/* subband transform - if stereo, interleaves pcm LRLRLR */
if (Subband(mp3DecInfo, outbuf + gr*mp3DecInfo->nGranSamps*mp3DecInfo->nChans) < 0)
return ERR_MP3_INVALID_SUBBAND;
return ERR_MP3_NONE;
我仿真一直跟踪没有看到一个地方是输出PCM数据的就是你的outBuf缓存区,不知道为啥,是不是那里出错没有执行到,如果出错就会跳出这个函数的,我是整个函数顺利执行完成的 |
