查看: 10131|回复: 5
串口无法接收数据问题跪求解决
发表于 2016-1-23 22:49:12 | 显示全部楼层 |阅读模式
F4勾选了microl lib选项,串口调试无法接收数据???(TX,RX短接后数据在串口调试助手显示正常)
 楼主| 发表于 2016-1-23 22:50:07 | 显示全部楼层
  1. void NVIC_USART1_Config(void)
  2. {
  3.         NVIC_InitTypeDef NVIC_InitStructure;
  4.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  5.
  6.         NVIC_InitStructure.NVIC_IRQChannel=USART1_IRQn;
  7.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;
  8.         NVIC_InitStructure.NVIC_IRQChannelSubPriority=1;
  9.         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  10.         NVIC_Init(&NVIC_InitStructure);
  11. }
  12. void USART1_Config(void)
  13. {
  14.         GPIO_InitTypeDef GPIO_InitStructure;
  15.         USART_InitTypeDef USART_InitStructure;
  16.
  17.
  18.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA , ENABLE);
  19.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  20.         //′®¿ú1¶Ôó|òy½Å¸′óÃó3éä
  21.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
  22.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
  23.
  24.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  25.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  26.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  28.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  29.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  30.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  31.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  32.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  33.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  34.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  35.
  36.
  37.         USART_InitStructure.USART_BaudRate=9600;
  38.         USART_InitStructure.USART_WordLength=USART_WordLength_8b;
  39.         USART_InitStructure.USART_StopBits=USART_StopBits_1;
  40.         USART_InitStructure.USART_Parity=USART_Parity_No;
  41.         USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
  42.         USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
  43.
  44.         USART_Init(USART1,&USART_InitStructure);
  45.         NVIC_USART1_Config();
  46.         USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
  47.
  48.         USART_Cmd(USART1,ENABLE);
  49. }
发表于 2016-1-25 08:41:09 | 显示全部楼层
使用printf函数需要添加下面两个函数才行
我们都有相关的例程,你对比看看哪里设置错了
///重定向c库函数printf到串口DEBUG_USART,重定向后可使用printf函数
int fputc(int ch, FILE *f)
                /* 发送一个字节数据到串口DEBUG_USART */
                USART_SendData(DEBUG_USART, (uint8_t) ch);
                /* 等待发送完毕 */
                while (USART_GetFlagStatus(DEBUG_USART, USART_FLAG_TXE) == RESET);
                return (ch);
///重定向c库函数scanf到串口DEBUG_USART,重写向后可使用scanf、getchar等函数
int fgetc(FILE *f)
                /* 等待串口输入数据 */
                while (USART_GetFlagStatus(DEBUG_USART, USART_FLAG_RXNE) == RESET);
                return (int)USART_ReceiveData(DEBUG_USART);
 楼主| 发表于 2016-1-26 10:50:40 | 显示全部楼层
这两个函数加了的  那个微库选项也勾选了
 楼主| 发表于 2016-1-26 10:51:14 | 显示全部楼层
///重定向c库函数 ...
这两个函数加了的  那个微库选项也勾选了
发表于 2016-1-26 10:58:24 | 显示全部楼层
GMT+8, 2025-1-11 14:06 , Processed in 0.039998 second(s), 23 queries , Gzip On.
