查看: 13552|回复: 3
LCD驱动代码解疑
发表于 2016-3-10 11:38:06 | 显示全部楼层 |阅读模式
bsp_LCD.h文件里
#define HBP  24
#define VBP   3
#define HSW   6
#define VSW   1
#define HFP  10
#define VFP   4
以上代码怎么和屏资料对应?
file:///C:\Users\king\AppData\Roaming\Tencent\Users\42607370\QQ\WinTemp\RichOle\KBU]}E4AGI(@{%6Q7I`S](R.png
bsp_LCD.c文件里
/* LTDC Configuration *********************************************************/
/* Polarity configuration */
/* Initialize the horizontal synchronization polarity as active low */
LTDC_InitStruct.LTDC_HSPolarity = LTDC_HSPolarity_AL;
/* Initialize the vertical synchronization polarity as active low */
LTDC_InitStruct.LTDC_VSPolarity = LTDC_VSPolarity_AL;
/* Initialize the data enable polarity as active low */
LTDC_InitStruct.LTDC_DEPolarity = LTDC_DEPolarity_AL;
/* Initialize the pixel clock polarity as input pixel clock */
LTDC_InitStruct.LTDC_PCPolarity = LTDC_PCPolarity_IPC;
屏驱动信号DE极性和资料不一致,是不是资料描述不对?
屏资料时序表
屏资料时序表
时序信号
时序信号
发表于 2016-3-10 11:52:16 | 显示全部楼层
按资料来做不正确,改成相反的就对了,
估计资料跟实际产品有点差异
 楼主| 发表于 2016-3-10 11:57:21 | 显示全部楼层
flyleaf 发表于 2016-3-10 11:52
按资料来做不正确,改成相反的就对了,
估计资料跟实际产品有点差异
驱动头文件里的几个参数呢?应该怎么对应时序参数?
发表于 2016-3-10 13:34:19 | 显示全部楼层
看教程文档,里边有写
GMT+8, 2024-11-22 16:15 , Processed in 0.029911 second(s), 27 queries , Gzip On.
