查看: 15054|回复: 3
UCOSII信号量按不按按键灯都一直亮,闪亮才是正常现象
发表于 2016-3-18 16:07:19 | 显示全部楼层 |阅读模式
现在灯一直常亮,怎么按都没反应
发表于 2016-3-18 18:33:26 | 显示全部楼层
你的按键任务没有初始化
 楼主| 发表于 2016-3-19 15:48:33 | 显示全部楼层
flyleaf 发表于 2016-3-18 18:33
你的按键任务没有初始化
火哥,现在变成不按按键它也闪了
#ifndef  __APP_CFG_H__
#define  __APP_CFG_H__
#define STARTUP_TASK_PRIO       5
#define STARTUP_LED1_PRIO       4
#define STARTUP_KEY_PRIO     3
#define STARTUP_TASK_STK_SIZE   80
#define STARTUP_LED1_STK_SIZE  80
#define STARTUP_KEY_STK_SIZE   128
#endif
APP.c
#include "includes.h"
OS_EVENT *Sem;
INT8U err;
static OS_STK STARTUP_LED1_STK[STARTUP_LED1_STK_SIZE];
static OS_STK STARTUP_KEY_STK[STARTUP_KEY_STK_SIZE];
void Task_LED1(void *pdata)
  pdata=pdata;
            SysTick_init();
    while (1)
                        OSSemPend(Sem,0,&err);
                                for(;;)
        LED1( ON );
        OSTimeDly(1000);
        LED1( OFF);
                        OSTimeDly(1000);
        LED2( ON );
        OSTimeDly(1000);
        LED2( OFF);
                        OSTimeDly(1000);
void Task_KEY(void *pdata)
        INT8U KeyAState;
        pdata=pdata;
                OSTimeDly(20);
                KeyAState=GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13);
                if(KeyAState==0)
                                OSTimeDly(20);
     if(KeyAState==0)
      Sem=OSSemCreate(0);
                        OSSemPost(Sem);
void Task_LED(void *pdata)
      pdata=pdata;
            SysTick_init();
    while (1)
                                OSTaskCreate(Task_LED1,(void *) 0,(OS_STK *)&STARTUP_LED1_STK[STARTUP_LED1_STK_SIZE-1], STARTUP_LED1_PRIO );
              OSTaskCreate(Task_KEY,(void *) 0,(OS_STK *)&STARTUP_KEY_STK[STARTUP_KEY_STK_SIZE-1], STARTUP_KEY_PRIO );
main.c
static OS_STK STARTUP_start_STK[STARTUP_TASK_STK_SIZE];
  BSP_Init();
        OSInit();
        OSTaskCreate(Task_LED,(void *) 0,(OS_STK *)&STARTUP_start_STK[STARTUP_TASK_STK_SIZE-1], STARTUP_TASK_PRIO );
        OSStart();
        return 0;
 楼主| 发表于 2016-3-21 09:12:41 | 显示全部楼层
帮贫民看看吧
GMT+8, 2024-11-24 03:48 , Processed in 0.043023 second(s), 26 queries , Gzip On.
