查看: 11386|回复: 1
求指导
发表于 2016-3-24 13:59:10 | 显示全部楼层 |阅读模式
#define TIM_OCMode_Timing                  ((uint16_t)0x0000)
#define TIM_OCMode_Active                  ((uint16_t)0x0010)
#define TIM_OCMode_Inactive                ((uint16_t)0x0020)
#define TIM_OCMode_Toggle                  ((uint16_t)0x0030)
#define TIM_OCMode_PWM1                    ((uint16_t)0x0060)
#define TIM_OCMode_PWM2                    ((uint16_t)0x0070)
#define IS_TIM_OC_MODE(MODE) (((MODE) == TIM_OCMode_Timing) || \
                              ((MODE) == TIM_OCMode_Active) || \
                              ((MODE) == TIM_OCMode_Inactive) || \
                              ((MODE) == TIM_OCMode_Toggle)|| \
                              ((MODE) == TIM_OCMode_PWM1) || \
                              ((MODE) == TIM_OCMode_PWM2))
#define IS_TIM_OCM(MODE) (((MODE) == TIM_OCMode_Timing) || \
                          ((MODE) == TIM_OCMode_PWM2) ||        \
                          ((MODE) == TIM_ForcedAction_Active) || \
                          ((MODE) == TIM_ForcedAction_InActive))
看不懂这个程序后边的那一部分,什么意思啊
发表于 2016-3-24 14:13:43 | 显示全部楼层
判断输入的参数是不是上面定义的那几个
GMT+8, 2024-11-23 17:12 , Processed in 0.039971 second(s), 23 queries , Gzip On.
