..\LED-REG.axf: Error: L6200E: Symbol SystemInit multiply defined (by system_stm32f4xx.o and main.o).
..\LED-REG.axf: Error: L6200E: Symbol __Vectors_Size multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol __heap_base multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol __heap_limit multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol __Vectors multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol __Vectors_End multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol __initial_sp multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol Reset_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol NMI_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol HardFault_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol MemManage_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol BusFault_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol UsageFault_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol SVC_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DebugMon_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol PendSV_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol SysTick_Handler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol ADC_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN1_RX0_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN1_RX1_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN1_SCE_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN1_TX_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN2_RX0_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN2_RX1_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN2_SCE_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol CAN2_TX_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DCMI_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream0_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream1_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream2_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream3_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream4_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream5_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream6_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA1_Stream7_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2D_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream0_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream1_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream2_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream3_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream4_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream5_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream6_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol DMA2_Stream7_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol ETH_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol ETH_WKUP_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI0_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI15_10_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI1_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI2_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI3_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI4_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol EXTI9_5_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol FLASH_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol FMC_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol FPU_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol HASH_RNG_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol I2C1_ER_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol I2C1_EV_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol I2C2_ER_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol I2C2_EV_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol I2C3_ER_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol I2C3_EV_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol LTDC_ER_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol LTDC_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol OTG_FS_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol OTG_FS_WKUP_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol OTG_HS_EP1_IN_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol OTG_HS_EP1_OUT_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol OTG_HS_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol OTG_HS_WKUP_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
..\LED-REG.axf: Error: L6200E: Symbol PVD_IRQHandler multiply defined (by startup_stm32f429xx.o and startup_stm32f429_439xx.o).
