查看: 9506|回复: 2
F429 OV2640摄像头+ucos3移植失败,没图像
发表于 2016-4-27 14:30:27 | 显示全部楼层 |阅读模式
把F429的摄像头裸机例程代码移植到ucos3的LED灯的例程里面以后,编译通过,lcd能正常显示打印的语句,不知道为什么就是没有图像?请大家指教指教,谢谢!
 楼主| 发表于 2016-4-27 15:13:17 | 显示全部楼层
我把ov2640例程mian函数里的东西都加进入到了AppTaskStart里面了。
static  void  AppTaskStart (void *p_arg)
    CPU_INT32U  cpu_clk_freq;
    CPU_INT32U  cnts;
    OS_ERR      err;
   (void)p_arg;
    BSP_Init();                                                 /* Initialize BSP functions                             */
    CPU_Init();
    cpu_clk_freq = BSP_CPU_ClkFreq();                           /* Determine SysTick reference freq.                    */
    cnts = cpu_clk_freq / (CPU_INT32U)OSCfg_TickRate_Hz;        /* Determine nbr SysTick increments                     */
    OS_CPU_SysTickInit(cnts);                                   /* Init uC/OS periodic time src (SysTick).              */
    Mem_Init();                                                 /* Initialize Memory Management Module                  */
#if OS_CFG_STAT_TASK_EN > 0u
    OSStatTaskCPUUsageInit(&err);                               /* Compute CPU capacity with no task running            */
#endif
#ifdef CPU_CFG_INT_DIS_MEAS_EN
    CPU_IntDisMeasMaxCurReset();
#endif
                                               /* Init uC/OS-III.                                      */
  Debug_USART_Config();
        SysTick_Init();
  LCD_Init();
  LCD_LayerInit();
  LTDC_Cmd(ENABLE);
        /*°Ñ±3¾°2ãË¢oúé«*/
  LCD_SetLayer(LCD_BACKGROUND_LAYER);
        LCD_SetTransparency(0xFF);
        LCD_Clear(LCD_COLOR_BLACK);
        LCD_SetLayer(LCD_FOREGROUND_LAYER);
        LCD_Clear(TRANSPARENCY);
        LCD_SetColors(LCD_COLOR_RED,TRANSPARENCY);
        LCD_ClearLine(LINE(18));
  LCD_DisplayStringLine_EN_CH(LINE(18),(uint8_t* )" Ä£ê½:VGA 800x480");
  CAMERA_DEBUG("STM32F429 DCMI Çy¶ˉOV2640ày3ì");
  OV2640_HW_Init();
  OV2640_ReadID(&OV2640_Camera_ID);
   if(OV2640_Camera_ID.PIDH  == 0x26)
//    sprintf((char*)dispBuf, "              OV2640 éãÏñí·,ID:0x%x", OV2640_Camera_ID.PIDH);
//                LCD_DisplayStringLine_EN_CH(LINE(0),(uint8_t*)dispBuf);
    LCD_SetTextColor(LCD_COLOR_RED);
    LCD_DisplayStringLine_EN_CH(LINE(0),(uint8_t*) "         Ã»óD¼ì2aμ½OV2640£¬ÇëÖØD¼ì2éᬽó¡£");
    CAMERA_DEBUG("%s",dispBuf);
    while(1);
  OV2640_QVGAConfig();
  OV2640_Init();
  DCMI_Cmd(ENABLE);
  DCMI_CaptureCmd(ENABLE);
#if FRAME_RATE_DISPLAY
                if(Task_Delay[0]==0)
                        LCD_ClearLine(LINE(17));
                        sprintf((char*)dispBuf, " Ö¡Âê:%.1f/s", (float)fps/5.0);
                        LCD_DisplayStringLine_EN_CH(LINE(17),dispBuf);
                        fps =0;
                        Task_Delay[0]=5000; //′ËÖμÿ1ms»á¼õ1£¬¼õμ½02Å¿éòÔÖØD½øà′Õaàï
#endif
发表于 2016-4-27 16:41:02 | 显示全部楼层
可以参考一下这个例程,不过是使用了emwin的:
光盘目录:3-程序源码.zip\3-程序源码\3-emwin例程.zip\3-emwin例程\26. uCOSIII_emWin528_Camera
或者出厂综合例程
GMT+8, 2025-4-10 04:34 , Processed in 0.062858 second(s), 25 queries , Gzip On.
