查看: 12395|回复: 4
GUIBuilder生成的代码如何移植到开发板?
发表于 2016-5-1 14:59:04 | 显示全部楼层 |阅读模式
以下是生成的代码,
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
* C-file generated by:                                               *
*        GUI_Builder for emWin version 5.22                          *
*        Compiled Jul  4 2013, 15:16:01                              *
*        (c) 2013 Segger Microcontroller GmbH & Co. KG               *
*        Internet: www.segger.com  Support: support@segger.com       *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
#include "Builder.h"
*       Defines
#define ID_FRAMEWIN_0  (GUI_ID_USER + 0x00)
#define ID_BUTTON_0  (GUI_ID_USER + 0x01)
#define ID_BUTTON_1  (GUI_ID_USER + 0x02)
#define ID_SLIDER_0  (GUI_ID_USER + 0x03)
#define ID_LISTVIEW_0  (GUI_ID_USER + 0x04)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
  { FRAMEWIN_CreateIndirect, "GUIBuilder", ID_FRAMEWIN_0, 0, 2, 240, 320, 0, 0x64, 0 },
  { BUTTON_CreateIndirect, "on", ID_BUTTON_0, 26, 205, 80, 40, 0, 0x0, 0 },
  { BUTTON_CreateIndirect, "off", ID_BUTTON_1, 122, 205, 80, 40, 0, 0x0, 0 },
  { SLIDER_CreateIndirect, "Slider", ID_SLIDER_0, 37, 154, 157, 20, 0, 0x0, 0 },
  { LISTVIEW_CreateIndirect, "Listview", ID_LISTVIEW_0, 15, 8, 196, 130, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
static void _cbDialog(WM_MESSAGE * pMsg) {
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  // USER START (Optionally insert additional variables)
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'GUIBuilder'
    hItem = pMsg->hWin;
    FRAMEWIN_SetFont(hItem, GUI_FONT_20B_1);
    FRAMEWIN_SetText(hItem, "Framewin");
    FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    FRAMEWIN_SetTextColor(hItem, 0x00FF0000);
    // Initialization of 'on'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0);
    BUTTON_SetFont(hItem, GUI_FONT_20B_1);
    // Initialization of 'off'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_1);
    BUTTON_SetFont(hItem, GUI_FONT_20_1);
    // Initialization of 'Listview'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0);
    LISTVIEW_AddColumn(hItem, 30, "Col 0", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddColumn(hItem, 30, "Col 1", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddColumn(hItem, 30, "Col 2", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddRow(hItem, NULL);
    LISTVIEW_SetGridVis(hItem, 1);
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
    break;
  case WM_NOTIFY_PARENT:
    Id    = WM_GetId(pMsg->hWinSrc);
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_BUTTON_0: // Notifications sent by 'on'
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        // USER START (Optionally insert code for reacting on notification message)
        // USER END
        break;
      case WM_NOTIFICATION_RELEASED:
        // USER END
        break;
      // USER START (Optionally insert additional code for further notification handling)
      // USER END
      break;
    case ID_BUTTON_1: // Notifications sent by 'off'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
      // USER END
      break;
    case ID_SLIDER_0: // Notifications sent by 'Slider'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
      case WM_NOTIFICATION_VALUE_CHANGED:
        // USER END
        break;
      // USER END
      break;
    case ID_LISTVIEW_0: // Notifications sent by 'Listview'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
      case WM_NOTIFICATION_SEL_CHANGED:
        // USER END
        break;
      // USER END
      break;
    // USER START (Optionally insert additional code for further Ids)
    // USER END
    break;
  // USER START (Optionally insert additional message handling)
  // USER END
  default:
    WM_DefaultProc(pMsg);
    break;
*       Public code
*       CreateGUIBuilder
WM_HWIN CreateGUIBuilder(void);
WM_HWIN CreateGUIBuilder(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
// USER START (Optionally insert additional public code)
// USER END
/*************************** End of file ****************************/
在主函数中调用出现的错误;
在主函数中调用出现的错误;
发表于 2016-5-2 09:40:04 | 显示全部楼层
你这叫函数数调用嘛?完全是一个函数声明的格式
 楼主| 发表于 2016-5-3 23:06:12 | 显示全部楼层
明白了,多谢了。
 楼主| 发表于 2016-5-3 23:17:30 | 显示全部楼层
刚刚接触 emwin,啥都不懂。
好了
好了
发表于 2016-5-4 09:37:37 | 显示全部楼层
1056991651 发表于 2016-5-3 23:17
刚刚接触 emwin,啥都不懂。
不错嘛
GMT+8, 2025-4-16 07:07 , Processed in 0.104414 second(s), 26 queries , Gzip On.
