查看: 11030|回复: 2
有哪位大神弄出来中文矢量字体了吗.......
发表于 2016-5-11 12:34:47 | 显示全部楼层 |阅读模式
有哪位大神弄出来中文矢量字体了吗?求分享下经验或代码.
发表于 2016-5-11 14:08:43 | 显示全部楼层
帮顶
发表于 2016-5-11 14:24:35 | 显示全部楼层
#ifndef SKIP_TEST
#include <windows.h>
#include <stdio.h>
#include "GUI.h"
*       Static data
static unsigned     _aHeight  [] = {16, 20, 32, 48};   // Array of heights used to show text
static GUI_TTF_CS   _aCS      [GUI_COUNTOF(_aHeight)]; // Each GUI font needs its own GUI_TTF_CS structure
static GUI_FONT     _aFont    [GUI_COUNTOF(_aHeight)]; // Array of GUI fonts
static char         _acFamily [200];
static char         _acStyle  [200];
*       Static code
*       _ShowText
static void _ShowText(void) {(1)
  int i;
  GUI_Clear();
  i = 0;
  GUI_TTF_GetFamilyName(&_aFont[i], _acFamily, sizeof(_acFamily));(2)
  GUI_TTF_GetStyleName(&_aFont[i],  _acStyle,  sizeof(_acStyle));
  GUI_SetFont(&GUI_Font20_1);
  GUI_DispString(_acFamily);
  GUI_DispString(", ");
  GUI_DispString(_acStyle);
  GUI_DispNextLine();
  GUI_DrawHLine(GUI_GetDispPosY(), 0, 0xfff);
  GUI_SetFont(&_aFont[i]);
  GUI_DispString("abcdefghijklmnopqrstuvwxyz\n");
  GUI_DispString("ABCDEFGHIJKLMNOPQRSTUVWXYZ\n");
  GUI_DispString("123456789.:,;(:*!?')\n");
  for (i = 0; i < GUI_COUNTOF(_aHeight); i++) {
    GUI_DispString("The quick brown fox jumps over the lazy dog. 1234567890\n");
  GUI_Delay(1000);
*       _CreateFonts
static int _CreateFonts(const U8 * pData, U32 NumBytes) {(3)
  int i;
  GUI_TTF_DATA TTF_Data;        // Only one GUI_TTF_DATA structure is used per font face
  TTF_Data.pData    = pData;    // Set pointer to file data
  TTF_Data.NumBytes = NumBytes; // Set size of file
    // Initialize GUI_TTF_CS members
    _aCS[i].PixelHeight = _aHeight[i];
    _aCS[i].pTTF        = &TTF_Data;
    // Create GUI font
    if (GUI_TTF_CreateFont(&_aFont[i], &_aCS[i])) {(4)
      return 1;
  return 0;
*       _cbFontDemo
* Function description
*   The function uses the given pointer to a true type font for creating
*   a couple of GUI fonts and showing the outline of the TTF font.
* Parameters:
*   pData    - Location of font file
*   NumBytes - Size of font file
static void _cbFontDemo(const U8 * pData, U32 NumBytes) {(5)
  _CreateFonts(pData, NumBytes); // Create fonts
  _ShowText();                   // Show some text
  GUI_TTF_DestroyCache();        // Clear the TTF cache
*       _IterateOverAllFiles
*   The function iterates over all files of the given folder and the
*   given mask, reads the contents of the file and calls the function
*   pfDoSomething() with location and size of file data.
*   Can be used under Win32 environment only.
static void _IterateOverAllFiles(const char * sFolder, const char * sMask, void (* pfDoSomething)(const U8 * pData, U32 NumBytes)) {(6)
  GUI_RECT Rect = {0, 10, 1000, 1000};
  char              acMask[_MAX_PATH];
  char              acFile[_MAX_PATH];
  WIN32_FIND_DATA   Context;
  HANDLE            hFind;
  HANDLE            hFile;
  U8              * pData;
  DWORD             NumBytes;
  DWORD             NumBytesRead;
  sprintf(acMask, "%s\\%s", sFolder, sMask);
  hFind = FindFirstFile(acMask, &Context);
  if (hFind != INVALID_HANDLE_VALUE) {
    do {
      sprintf(acFile, "%s\\%s", sFolder, Context.cFileName);
      hFile = CreateFile(acFile, GENERIC_READ, FILE_SHARE_READ, 0, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, 0);
      if (hFile != INVALID_HANDLE_VALUE) {
        NumBytes = GetFileSize(hFile, NULL);
        pData = (U8 *)malloc(NumBytes);
        ReadFile(hFile, pData, NumBytes, &NumBytesRead, NULL);
        pfDoSomething(pData, NumBytes);
        free(pData);
      CloseHandle(hFile);
    } while (FindNextFile(hFind, &Context));
*       Public code
*       MainTask
void MainTask(void) {
  char acPath[200];
  GUI_Init();
  // Set colors and text mode
  GUI_SetBkColor(GUI_WHITE);
  GUI_SetColor(GUI_BLACK);
  GUI_SetTextMode(GUI_TM_TRANS);
  // Get windows system directory and extend it with '\Font'(7)
  GetWindowsDirectory(acPath, sizeof(acPath));
  strcat(acPath, "\\Fonts");
  // Iterate over files and call _cbFontDemo for each file
  while (1) {
    _IterateOverAllFiles(acPath, "*.ttf", _cbFontDemo);
#endif
GMT+8, 2024-11-23 03:09 , Processed in 0.028757 second(s), 24 queries , Gzip On.
