查看: 12738|回复: 1
关于win7和xp下的网络连接
发表于 2016-5-12 09:21:02 | 显示全部楼层 |阅读模式
麻烦问一下火哥,win7和xp的网络设置一样吗?现在我遇到的问题是,在win7下开发板和电脑连接正常,开关网络助手和插拔网线都正常,但是在xp下开关一下网络助手或者插拔网线之后 就不上传数据了,不知道为什么?
它会死在:
tcp_input(struct pbuf *p, struct netif *inp)中的
for(pcb = tcp_active_pcbs; pcb != NULL; pcb = pcb->next) {
    LWIP_ASSERT("tcp_input: active pcb->state != CLOSED", pcb->state != CLOSED);
    LWIP_ASSERT("tcp_input: active pcb->state != TIME-WAIT", pcb->state != TIME_WAIT);
    LWIP_ASSERT("tcp_input: active pcb->state != LISTEN", pcb->state != LISTEN);
    if (pcb->remote_port == tcphdr->src &&
       pcb->local_port == tcphdr->dest &&
       ip_addr_cmp(&(pcb->remote_ip), &current_iphdr_src) &&
       ip_addr_cmp(&(pcb->local_ip), &current_iphdr_dest)) {
      /* Move this PCB to the front of the list so that subsequent
         lookups will be faster (we exploit locality in TCP segment
         arrivals). */
      LWIP_ASSERT("tcp_input: pcb->next != pcb (before cache)", pcb->next != pcb);
      if (prev != NULL) {
        prev->next = pcb->next;
        pcb->next = tcp_active_pcbs;
        tcp_active_pcbs = pcb;
      LWIP_ASSERT("tcp_input: pcb->next != pcb (after cache)", pcb->next != pcb);
      break;
    prev = pcb;
发表于 2016-5-12 17:15:05 | 显示全部楼层
没什么区别,有可能的就是防火墙了
GMT+8, 2024-11-24 01:25 , Processed in 0.051899 second(s), 23 queries , Gzip On.
