查看: 12929|回复: 2
U盘实验 编译有问题
发表于 2016-6-8 08:17:17 | 显示全部楼层 |阅读模式
F429  3-程序源码\1-固件库例程\1-固件库例程\U盘实验
U盘实验 编译有问题呀,我是用KEIL5编译的?难道还需要设置什么吗?
*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build target 'U盘读写测试'
compiling main.c...
..\..\USER\./APP/usbh_bsp.h(22): error:  #5: cannot open source input file "usb_bsp.h": No such file or directory
  #include "usb_bsp.h"
..\..\USER\main.c: 0 warnings, 1 error
compiling stm32f4xx_it.c...
..\..\USER\stm32f4xx_it.c(34): error:  #5: cannot open source input file "usb_bsp.h": No such file or directory
..\..\USER\stm32f4xx_it.c: 0 warnings, 1 error
compiling diskio.c...
..\..\USER\FATFS\diskio.c: 0 warnings, 1 error
compiling usb_hcd_int.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_OTG_Driver\src\usb_hcd_int.c": No such file or directory
..\..\Libraries\STM32_USB_OTG_Driver\src\usb_hcd_int.c: 0 warnings, 1 error
compiling usb_hcd.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_OTG_Driver\src\usb_hcd.c": No such file or directory
..\..\Libraries\STM32_USB_OTG_Driver\src\usb_hcd.c: 0 warnings, 1 error
compiling usb_core.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_OTG_Driver\src\usb_core.c": No such file or directory
..\..\Libraries\STM32_USB_OTG_Driver\src\usb_core.c: 0 warnings, 1 error
compiling usbh_core.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_core.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_core.c: 0 warnings, 1 error
compiling usbh_hcs.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_hcs.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_hcs.c: 0 warnings, 1 error
compiling usbh_ioreq.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_ioreq.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_ioreq.c: 0 warnings, 1 error
compiling usbh_stdreq.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_stdreq.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Core\src\usbh_stdreq.c: 0 warnings, 1 error
compiling usbh_msc_bot.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_bot.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_bot.c: 0 warnings, 1 error
compiling usbh_msc_core.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_core.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_core.c: 0 warnings, 1 error
compiling usbh_msc_scsi.c...
"no source": Error:  #5: cannot open source input file "..\..\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_scsi.c": No such file or directory
..\..\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_scsi.c: 0 warnings, 1 error
compiling usb_bsp.c...
..\..\USER\APP\usb_bsp.c(30): error:  #5: cannot open source input file "usb_bsp.h": No such file or directory
..\..\USER\APP\usb_bsp.c: 0 warnings, 1 error
compiling usbh_usr.c...
..\..\USER\./APP/usbh_usr.h(34): error:  #5: cannot open source input file "usbh_core.h": No such file or directory
  #include "usbh_core.h"
..\..\USER\APP\usbh_usr.c: 0 warnings, 1 error
"..\..\Output\U盘读写测试.axf" - 5 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:03
发表于 2016-6-8 08:58:13 | 显示全部楼层
光盘里的这个代码有问题,用这个代替:
USB_OTG—开发板作USB主机读取U盘.zip (2.05 MB, 下载次数: 15665)
 楼主| 发表于 2016-6-8 13:49:17 | 显示全部楼层
好的,谢谢了
GMT+8, 2025-1-12 10:53 , Processed in 0.042919 second(s), 26 queries , Gzip On.
