初中生
最后登录1970-1-1
在线时间 小时
注册时间2016-5-1
楼主 |
发表于 2016-7-24 11:55:44
显示全部楼层
问题:基本定时器(Time6、Time7)在配置是period时 给1000 可是到了PWM输出时就是配置成999 这是为什么????可是我看了手册都是从0开始计数到自动加载值(TIMx_ARR计数器的内容),然后重新从0开始计数并且产生一个计数器溢出事件。 谢谢谢谢!
void TIMx_Configuration(void)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
TIM_TimeBaseStructure.TIM_Period=1000;
TIM_TimeBaseStructure.TIM_Prescaler= 71;
TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
TIM_ClearFlag(TIM6, TIM_FLAG_Update);
TIM_ITConfig(TIM6,TIM_IT_Update,ENABLE);
TIM_Cmd(TIM6, ENABLE);
RCC_APB1PeriphClockCmd (RCC_APB1Periph_TIM6, DISABLE);
TIM_OCInitTypeDef TIM_OCInitStructure;
/* PWMDÅoÅμçƽìø±äÖμ */
u16 CCR1_Val = 500;
u16 CCR2_Val = 375;
u16 CCR3_Val = 250;
u16 CCR4_Val = 125;
macTIMx Channel1 duty cycle = (macTIMx_CCR1/ macTIMx_ARR+1)* 100% = 50%
macTIMx Channel2 duty cycle = (macTIMx_CCR2/ macTIMx_ARR+1)* 100% = 37.5%
macTIMx Channel3 duty cycle = (macTIMx_CCR3/ macTIMx_ARR+1)* 100% = 25%
macTIMx Channel4 duty cycle = (macTIMx_CCR4/ macTIMx_ARR+1)* 100% = 12.5%
PWM输出配置
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 999;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM3, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
TIM_OC2Init(TIM3, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(macTIMx, TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
TIM_OC3Init(TIM3, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
/* PWM1 Mode configuration: Channel4 */
TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
TIM_OC4Init(macTIMx, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3, ENABLE);
TIM_Cmd(TIM3, ENABLE); |
