初中生
最后登录1970-1-1
在线时间 小时
注册时间2016-8-4
楼主 |
发表于 2016-8-8 16:11:39
显示全部楼层
typedef enum
* @brief SDIO specific error defines
SD_CMD_CRC_FAIL = (1), /*!< Command response received (but CRC check failed) */
SD_DATA_CRC_FAIL = (2), /*!< Data bock sent/received (CRC check Failed) */
SD_CMD_RSP_TIMEOUT = (3), /*!< Command response timeout */
SD_DATA_TIMEOUT = (4), /*!< Data time out */
SD_TX_UNDERRUN = (5), /*!< Transmit FIFO under-run */
SD_RX_OVERRUN = (6), /*!< Receive FIFO over-run */
SD_START_BIT_ERR = (7), /*!< Start bit not detected on all data signals in widE bus mode */
SD_CMD_OUT_OF_RANGE = (8), /*!< CMD's argument was out of range.*/
SD_ADDR_MISALIGNED = (9), /*!< Misaligned address */
SD_BLOCK_LEN_ERR = (10), /*!< Transferred block length is not allowed for the card or the number of transferred bytes does not match the block length */
SD_ERASE_SEQ_ERR = (11), /*!< An error in the sequence of erase command occurs.*/
SD_BAD_ERASE_PARAM = (12), /*!< An Invalid selection for erase groups */
SD_WRITE_PROT_VIOLATION = (13), /*!< Attempt to program a write protect block */
SD_LOCK_UNLOCK_FAILED = (14), /*!< Sequence or password error has been detected in unlock command or if there was an attempt to access a locked card */
SD_COM_CRC_FAILED = (15), /*!< CRC check of the previous command failed */
SD_ILLEGAL_CMD = (16), /*!< Command is not legal for the card state */
SD_CARD_ECC_FAILED = (17), /*!< Card internal ECC was applied but failed to correct the data */
SD_CC_ERROR = (18), /*!< Internal card controller error */
SD_GENERAL_UNKNOWN_ERROR = (19), /*!< General or Unknown error */
SD_STREAM_READ_UNDERRUN = (20), /*!< The card could not sustain data transfer in stream read operation. */
SD_STREAM_WRITE_OVERRUN = (21), /*!< The card could not sustain data programming in stream mode */
SD_CID_CSD_OVERWRITE = (22), /*!< CID/CSD overwrite error */
SD_WP_ERASE_SKIP = (23), /*!< only partial address space was erased */
SD_CARD_ECC_DISABLED = (24), /*!< Command has been executed without using internal ECC */
SD_ERASE_RESET = (25), /*!< Erase sequence was cleared before executing because an out of erase sequence command was received */
SD_AKE_SEQ_ERROR = (26), /*!< Error in sequence of authentication. */
SD_INVALID_VOLTRANGE = (27),
SD_ADDR_OUT_OF_RANGE = (28),
SD_SWITCH_ERROR = (29),
SD_SDIO_DISABLED = (30),
SD_SDIO_FUNCTION_BUSY = (31),
SD_SDIO_FUNCTION_FAILED = (32),
SD_SDIO_UNKNOWN_FUNCTION = (33),
* @brief Standard error defines
SD_INTERNAL_ERROR,
SD_NOT_CONFIGURED,
SD_REQUEST_PENDING,
SD_REQUEST_NOT_APPLICABLE,
SD_INVALID_PARAMETER,
SD_UNSUPPORTED_FEATURE,
SD_UNSUPPORTED_HW,
SD_ERROR,
SD_OK = 0
} SD_Error;
这个就是把SD_OK的值赋给Status |
