查看: 13840|回复: 2
LCD12864数据口处理
发表于 2016-8-29 10:44:27 | 显示全部楼层 |阅读模式
我目前用的屏跟LCD12864差不多,有点区别,厂家给的51的程序,改的时候,出现个问题,我往数据口写入0x55。示波器原本显示应该是10101010(从D0-D7),但是有错误。为高的时候正常,为低的时候就乱掉了。分析过来,应该是IO口设置的时候有问题。应该先设置为输入,再设置为输出。刚接触stm32,不知道这块单片机是怎么处理的。
#define LCD_DATA_IN()  GPIOE->CRL=0x88888888   //éèÖÃêy¾Y¶Ë¿úÎaéÏà-êäèë
#define LCD_DATA_INPORT GPIOE->IDR             //¶¨òåêy¾Yêäèë¶Ë¿ú
#define LCD_DATA_OUT() GPIOE->CRL=0x33333333   //éèÖÃêy¾Y¶Ë¿úÎaíÆíìêä3ö
#define LCD_DATA_OUTPORT GPIOE->ODR                   //¶¨òåêy¾Yêä3ö¶Ë¿ú
//LCD¶Ë¿ú3õê¼»ˉ
void LCD_GPIOInit(void)
  GPIO_InitTypeDef GPIO_InitStructure;                //¶¨òåGPIO½á11±äá¿
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE); //ê1ÄüAFIOê±Öó(ÏÂò»2ù×÷Ëù±ØDè)
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); //ÆôóÃSW-DP(1رÕÆäËûòÔ¿a·ÅIO¿ú)
  RCC_APB2PeriphClockCmd(LCD_RS_RCC, ENABLE);//ê1ÄüLCD_LCD_RSËùÔú¶Ë¿úê±Öó
  RCC_APB2PeriphClockCmd(LCD_RW_RCC, ENABLE);//ê1ÄüLCD_RWËùÔú¶Ë¿úê±Öó
  RCC_APB2PeriphClockCmd(LCD_EN_RCC, ENABLE);//ê1ÄüLCD_ENËùÔú¶Ë¿úê±Öó
        RCC_APB2PeriphClockCmd(LCD_RES_RCC, ENABLE);//ê1ÄüLCD_RESËùÔú¶Ë¿úê±Öó
  RCC_APB2PeriphClockCmd(LCD_CS1_RCC, ENABLE);//ê1ÄüLCD_CS1ËùÔú¶Ë¿úê±Öó
  //LCD_RS¶Ë¿ú3õê¼»ˉ
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //íÆíìêä3ö
  GPIO_InitStructure.GPIO_Pin = LCD_RS_PIN;
  GPIO_Init(LCD_RS_PORT, &GPIO_InitStructure);
  GPIO_SetBits(LCD_RS_PORT,LCD_RS_PIN); //LCD_RSêä3ö¸ßμçƽ
  //LCD_RW¶Ë¿ú3õê¼»ˉ
  GPIO_InitStructure.GPIO_Pin = LCD_RW_PIN;
  GPIO_Init(LCD_RW_PORT, &GPIO_InitStructure);
  GPIO_SetBits(LCD_RW_PORT,LCD_RW_PIN); //LCD_RWêä3ö¸ßμçƽ
  //LCD_EN¶Ë¿ú3õê¼»ˉ
  GPIO_InitStructure.GPIO_Pin = LCD_EN_PIN;
  GPIO_Init(LCD_EN_PORT, &GPIO_InitStructure);
  GPIO_SetBits(LCD_EN_PORT,LCD_EN_PIN); //LCD_ENêä3ö¸ßμçƽ
        //LCD_RES¶Ë¿ú3õê¼»ˉ
  GPIO_InitStructure.GPIO_Pin = LCD_RES_PIN;
  GPIO_Init(LCD_RES_PORT, &GPIO_InitStructure);
  GPIO_SetBits(LCD_RES_PORT,LCD_RES_PIN); //LCD_RESêä3ö¸ßμçƽ
        //LCD_CS1¶Ë¿ú3õê¼»ˉ
  GPIO_InitStructure.GPIO_Pin = LCD_CS1_PIN;
  GPIO_Init(LCD_CS1_PORT, &GPIO_InitStructure);
  GPIO_SetBits(LCD_CS1_PORT,LCD_CS1_PIN); //LCD_CS1êä3ö¸ßμçƽ
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//ê1Äüêy¾Y¶Ë¿úê±Öó
//D′Ö¸áîμ½LCD
void LCD_Wcmd(u8 cmd)
LCD_DATA_OUTPORT = 0xff;
  LCD_DATA_IN();  //éèÖÃêy¾Y¶Ë¿úÎaéÏà-êäèë
  LCD_RS = 0;
  LCD_RW   = 1;
  LCD_EN   = 1;
  LCD_DATA_OUTPORT = cmd;
  LCD_DATA_OUT();
  LCD_CS1    = 0;
  LCD_RW     = 0;
  __NOP();__NOP();
         __NOP();__NOP();
  LCD_RW     = 1;
  LCD_CS1    = 1;
主函数:在while()中循环执行
LCD_Wcmd(0x55);
问题是,高电平正常,低电平出现了方波。
发表于 2016-8-29 11:03:19 来自手机 | 显示全部楼层
配置输入或者输出操作crl或者crh这两个寄存器,具体的看手册。读取数据用idr寄存器,输出数据用odr寄存器。
发表于 2016-8-29 11:04:12 来自手机 | 显示全部楼层
控制crl或者crh寄存器的时候要记得先清0,然后再配置。
GMT+8, 2024-11-22 07:34 , Processed in 0.041699 second(s), 23 queries , Gzip On.
