查看: 13914|回复: 2
STM32 FMC DMA
发表于 2016-9-13 19:33:45 | 显示全部楼层 |阅读模式
求助: 我这边使用STM32F446E-EVAL的开发板,SDRAM做保存要显示的图片,同时屏也是FMC驱动,显示使用DMA将SDAM中的图片发送到屏,但是DMA进了中断,但是屏没有显示,不知道是什么问题,请高手协助下。
用MCU将SDAM中的数据发送到屏已经OK,下面是DMA初始化代码:
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
        DMA_ClearFlag(SDRAM_DMA_STREAM, SDRAM_DMA_FLAG_FEIF | SDRAM_DMA_FLAG_DMEIF | SDRAM_DMA_FLAG_TEIF | SDRAM_DMA_FLAG_HTIF | SDRAM_DMA_FLAG_TCIF);
        /* DMA2 Stream0  or Stream7 disable */
        DMA_Cmd(SDRAM_DMA_STREAM, DISABLE);
        /* DMA2 Stream0  or Stream7 Config */
        DMA_DeInit(SDRAM_DMA_STREAM);
        DMA_InitStructure.DMA_Channel = SDRAM_DMA_CHANNEL;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(SDRAM_BANK_ADDR);
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)(&(FMC_BANK1->RAM));//(FMC_BANK1_RAM);
        DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToMemory;
        DMA_InitStructure.DMA_BufferSize = (uint32_t)38400;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Enable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
        DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst = DMA_MemoryBurst_Single;
        DMA_Init(SDRAM_DMA_STREAM, &DMA_InitStructure);
          DMA_ITConfig(SDRAM_DMA_STREAM, DMA_IT_TC, ENABLE);
 楼主| 发表于 2016-9-13 19:38:11 | 显示全部楼层
火哥,帮忙支持下,搞不定了
发表于 2016-9-13 21:42:17 | 显示全部楼层
使用DMA2D应该更适合,不过我也不会
GMT+8, 2024-11-24 05:32 , Processed in 0.025789 second(s), 23 queries , Gzip On.
