查看: 11698|回复: 4
求大神,GSM发送AT指令收不到应答数据
发表于 2016-10-11 14:16:06 | 显示全部楼层 |阅读模式
#include"stm32f10x.h"
#include "main.h"
#define LED_PORT GPIOB
u8 LED_Blink = 0;
u8 shu;
* Global variables
void GPIO_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB| RCC_APB2Periph_GPIOC |RCC_APB2Periph_GPIOD |RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_2 | GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 |GPIO_Pin_0 | GPIO_Pin_14 | GPIO_Pin_3 | GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 ;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4 ;
        GPIO_ResetBits( GPIOC, GPIO_Pin_4 ); //RI ENABLE
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15 ;
u16 jieshou[100];
u8 wei1=0;
u16 usarnum = 1;
void UART4_IRQHandler(void)
         if(USART_GetITStatus(UART4, USART_IT_RXNE) != RESET)
                usarnum=USART_ReceiveData(UART4);
                jieshou[wei1] = usarnum;
                wei1++;
void delay_ms(u16 nms)
        u32 temp;
        SysTick->LOAD = 9000*nms;
        SysTick->VAL = 0X00;
        SysTick->CTRL = 0X01;
        do
                temp = SysTick->CTRL;
        while((temp&0x01) && (!(temp&(1<<16))));
        SysTick->CTRL = 0x00;
        SysTick->VAL = 0x00;
void gsm_usart_init( void )
        USART_InitTypeDef USART_InitStructure ;
        RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART4, ENABLE );
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_Init( GPIOC, &GPIO_InitStructure );
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
        USART_InitStructure.USART_BaudRate = 115200;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None ;
        USART_Init( UART4, &USART_InitStructure );
        USART_ITConfig( UART4, USART_IT_RXNE, ENABLE );
        USART_Cmd( UART4, ENABLE );
void USART4_Puts(char * str)
    while(*str)
        USART_SendData(UART4, *str++);
        /* Loop until the end of transmission */
        while(USART_GetFlagStatus(UART4, USART_FLAG_TXE) == RESET);
void bsp_nvic_init( void )
        NVIC_InitTypeDef  NVIC_InitStructure;
        NVIC_PriorityGroupConfig( NVIC_PriorityGroup_2 );
        NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;
        NVIC_Init( &NVIC_InitStructure );
        Usart1_Init();
        bsp_nvic_init();
        gsm_usart_init();
        GPIO_Config();
        //上电
        GPIO_WriteBit(GPIOC, GPIO_Pin_6, Bit_SET);
        delay_ms(500);
        //开机
        GPIO_WriteBit(GPIOC, GPIO_Pin_5, Bit_SET);
        delay_ms(2000);
        GPIO_WriteBit(GPIOC, GPIO_Pin_5, Bit_RESET);
        //DTR置低
        GPIO_WriteBit(GPIOC, GPIO_Pin_4, Bit_RESET);
        USART4_Puts("AT\r");
        delay_ms(5000);
        delay_ms(3000);
                USART4_Puts("AT+GMR\r");
               for(i = 0; i<10; i++)
                    printf("%x, ", jieshou[i]);
发表于 2016-10-11 14:39:25 | 显示全部楼层
参考一下我们的例程
你用的模块是SIM900A  还是800A的?
 楼主| 发表于 2016-10-11 15:07:23 | 显示全部楼层
flyleaf 发表于 2016-10-11 14:39
参考一下我们的例程
使用的SIM800C, 参考了很多例程,中断接收函数就是接收不到数据,不知道怎么办好了
发表于 2016-10-11 18:09:25 | 显示全部楼层
SIM800跟900A的我们最近发现不兼容,需要点时间来调试下
发表于 2017-5-7 20:09:59 | 显示全部楼层
你这样直接贴代码是没人愿意看的。。,,
GMT+8, 2025-12-14 13:34 , Processed in 0.037910 second(s), 24 queries , Gzip On.
