查看: 11454|回复: 3
关于定时器1 CH4 触发ADC的疑问
发表于 2016-10-12 22:45:17 | 显示全部楼层 |阅读模式
最近在做FOC电机驱动,基于ST电机库2.0。用定时器1 CH4 触发ADC(双ADC同步注入模式)采集。在ADC配置中可以配置ADC触发注入组采集时间为
ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_T1_CC4); //TIM1 CH4触发
然而在配置TIM1作为输出源时候,函数TIM_SelectOutputTrigger(),并没有TIM1 CH4作为输出触发源的选项
  * @brief  Selects the TIMx Trigger Output Mode.
  * @param  TIMx: where x can be 1 to 8 to select the TIM peripheral.
  * @param  TIM_TRGOSource: specifies the Trigger Output source.
  *   This paramter can be one of the following values:
  *  - For all TIMx
  *     @arg TIM_TRGOSource_Reset:  The UG bit in the TIM_EGR register is used as the trigger output (TRGO).
  *     @arg TIM_TRGOSource_Enable: The Counter Enable CEN is used as the trigger output (TRGO).
  *     @arg TIM_TRGOSource_Update: The update event is selected as the trigger output (TRGO).
  *  - For all TIMx except TIM6 and TIM7
  *     @arg TIM_TRGOSource_OC1: The trigger output sends a positive pulse when the CC1IF flag
  *                              is to be set, as soon as a capture or compare match occurs (TRGO).
  *     @arg TIM_TRGOSource_OC1Ref: OC1REF signal is used as the trigger output (TRGO).
  *     @arg TIM_TRGOSource_OC2Ref: OC2REF signal is used as the trigger output (TRGO).
  *     @arg TIM_TRGOSource_OC3Ref: OC3REF signal is used as the trigger output (TRGO).
  *     @arg TIM_TRGOSource_OC4Ref: OC4REF signal is used as the trigger output (TRGO).
  * @retval None
void TIM_SelectOutputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_TRGOSource)
  /* Check the parameters */
  assert_param(IS_TIM_ALL_PERIPH(TIMx));
  assert_param(IS_TIM_TRGO_SOURCE(TIM_TRGOSource));
  /* Reset the MMS Bits */
  TIMx->CR2 &= CR2_MMS_Mask;
  /* Select the TRGO source */
  TIMx->CR2 |=  TIM_TRGOSource;
查看手册说明确实是存在TIM1 CH4触发ADC采集这个功能,但是TIM1中并没有找到相关标志位。。。。
请问各位,这个怎么搞??
发表于 2016-10-13 08:53:09 | 显示全部楼层
估计不是所有定时器都支持这个功能吧
 楼主| 发表于 2016-10-13 09:05:27 | 显示全部楼层
手册ADC框图
 楼主| 发表于 2016-10-13 09:06:06 | 显示全部楼层
相津童 发表于 2016-10-13 08:53
估计不是所有定时器都支持这个功能吧
看3楼图,注明了TIM1_CH4能外部触发ADC注入组
GMT+8, 2025-1-13 06:33 , Processed in 0.040420 second(s), 26 queries , Gzip On.
