大学生
最后登录1970-1-1
在线时间 小时
注册时间2015-7-7
void SPI_FLASH_Init(void)
SPI_InitTypeDef SPI_InitStructure;
/* Enable SPI1 and GPIO clocks */
/*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD, ENABLE);
/*!< SPI_FLASH_SPI Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
/*!< Configure SPI_FLASH_SPI pins: SCK */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
/*!< Configure SPI_FLASH_SPI pins: MISO */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
/*!< Configure SPI_FLASH_SPI pins: MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
/*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
/* Deselect the FLASH: Chip Select high */
SPI_FLASH_CS_HIGH();
/* SPI1 configuration */
// W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
// Data on the DO and DIO pins are clocked out on the falling edge of CLK.
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
/* Enable SPI1 */
SPI_Cmd(SPI1, ENABLE);
u8 SPI_FLASH_SendByte(u8 byte)
/* Loop while DR register in not emplty */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
/* Send byte through the SPI1 peripheral */
SPI_I2S_SendData(SPI1, byte);
/* Wait to receive a byte */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
/* Return the byte read from the SPI bus */
return SPI_I2S_ReceiveData(SPI1);
我用SPI接口 接了一个12864 引脚完全对应 没接MISO 引脚(因为12864没有)
是不是 我把这个程序全都拷贝过去 调用SPI_FLASH_SendByte(u8 byte) 这个函数
12864的时钟就跟着震荡起来了呢
SPI_FLASH_SendByte(0xfa); 我这样调用 是不是 这个数据0xfa 就发送出去了呢
我这个函数这样写
*函 数:SPI_write_data
*功 能:向LCD写入数据
*参 数:无
*返回值:无
void SPI_write_data(uint8_t Dispdata)
LCD_Busy();
SPI_FLASH_CS_HIGH(); //12864 高电平有效
Delay_ms(2);
SPI_FLASH_SendByte(Dispdata & 0xf0);
Delay_ms(2);
SPI_FLASH_SendByte((Dispdata << 4) & 0xf0);
Delay_ms(2);
SPI_FLASH_CS_LOW();
