查看: 12158|回复: 4
串口无法实现通信,如何确定是不是硬件问题?
发表于 2016-11-11 13:59:38 | 显示全部楼层 |阅读模式
我用的是老版本的M3,目测有些年头了。最近在用这块板子做串口通信试验,可以从板子上发送数据到PC上,但是无法从PC上发送数据到单片机。检查了好几遍串口中断程序,没发现什么问题。那么怎么检查是不是硬件问题?
老版本M3
老版本M3
以下是串口中断配置相关的代码:
  1. void USART1_Config(void)
  2. {
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         USART_InitTypeDef USART_InitStructure;
  5.
  6.         /* config USART1 clock */
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
  8.
  9.         /* USART1 GPIO config */
  10.         /* Configure USART1 Tx (PA.09) as alternate function push-pull */
  11.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  12.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  14.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  15.         /* Configure USART1 Rx (PA.10) as input floating */
  16.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  18.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  19.
  20.         /* USART1 mode config */
  21.         USART_InitStructure.USART_BaudRate = 115200;
  22.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  23.         USART_InitStructure.USART_StopBits = USART_StopBits_1;
  24.         USART_InitStructure.USART_Parity = USART_Parity_No ;
  25.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  26.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  27.         USART_Init(USART1, &USART_InitStructure);
  28.
  29.         //使能串口1 接收终中断
  30.         USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  31.
  32.         USART_Cmd(USART1, ENABLE);
  33. }
  34. void NVIC_Configuration(void)
  35. {
  36.         NVIC_InitTypeDef NVIC_InitStructure;
  37.         /* Configure the NVIC Preemption Priority Bits */
  38.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  39.
  40.         /* Enable the USARTy Interrupt */
  41.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  42.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  43.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  44.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  45.         NVIC_Init(&NVIC_InitStructure);
  46. }
这是串口中断函数
  1. void USART1_IRQHandler(void)
  2. {
  3.         u8 c;
  4.         printf("这是来自串口的中断");
  5.         if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
  6.         {
  7.             c=USART1->DR;
  8.                   printf("%c",c);    //将接受到的数据直接返回打印
  9.         }
  10.
  11. }
经测试,无法进入串口中断函数。向M3发送数据没有反应。
发表于 2016-11-11 14:05:20 | 显示全部楼层
下载我们配套的程序,不能用的话就是硬件有问题
一般能发送、不能接收,都是程序的原因
 楼主| 发表于 2016-11-11 14:17:30 | 显示全部楼层
一般能发送、不能接收,都是程序的原因
因为版本比较久远,配套的例程已经遗失,程序是我从论坛找到,从电路图看是同一版本。
例程没有经过修改,但是确实串口只能发送数据,不能接收数据。
 楼主| 发表于 2016-11-11 14:20:39 | 显示全部楼层
能否帮忙看下串口配置程序和串口中断程序是否有误?
发表于 2016-11-11 14:42:29 | 显示全部楼层
确实你的程序看起来没有问题
GMT+8, 2024-11-28 13:45 , Processed in 0.067842 second(s), 27 queries , Gzip On.
