查看: 11487|回复: 5
STM32F103ZET6 初始化FMSC出现hardfault_handler
发表于 2016-11-14 17:29:45 | 显示全部楼层 |阅读模式
火哥:
    在使用STM32F103zet6对显示屏初始化的时候,在
FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank] |=BCR_FACCEN_Set;出现hardfault_handler是怎么回事?
发表于 2016-11-14 17:47:56 | 显示全部楼层
看不懂你这代码
 楼主| 发表于 2016-11-14 17:59:32 | 显示全部楼层
        p.FSMC_AddressSetupTime      = 0x02;         //μØÖ·½¨á¢ê±¼ä
        p.FSMC_AddressHoldTime       = 0x00;         //μØÖ·±£3Öê±¼ä
        p.FSMC_DataSetupTime         = 0x05;         //êy¾Y½¨á¢ê±¼ä
        p.FSMC_BusTurnAroundDuration = 0x00;
        p.FSMC_CLKDivision           = 0x00;
        p.FSMC_DataLatency           = 0x00;
        p.FSMC_AccessMode            = FSMC_AccessMode_B;         //Ä£ê½B±è½ÏêêóÃóúILI9341
        FSMC_NORSRAMInitStructure.FSMC_Bank                  = macFSMC_Bank1_NORSRAMx;
        FSMC_NORSRAMInitStructure.FSMC_DataAddressMux        = FSMC_DataAddressMux_Disable;
        //FSMC_NORSRAMInitStructure.FSMC_MemoryType          = FSMC_MemoryType_SRAM;
        FSMC_NORSRAMInitStructure.FSMC_MemoryType            = FSMC_MemoryType_NOR;
        FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth       = FSMC_MemoryDataWidth_16b;
        FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode       = FSMC_BurstAccessMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity    = FSMC_WaitSignalPolarity_Low;
        FSMC_NORSRAMInitStructure.FSMC_WrapMode              = FSMC_WrapMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive      = FSMC_WaitSignalActive_BeforeWaitState;
        FSMC_NORSRAMInitStructure.FSMC_WriteOperation        = FSMC_WriteOperation_Enable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignal            = FSMC_WaitSignal_Disable;
        FSMC_NORSRAMInitStructure.FSMC_ExtendedMode          = FSMC_ExtendedMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WriteBurst            = FSMC_WriteBurst_Disable;
        FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = & p;
        FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct     = & p;
        FSMC_NORSRAMInit ( & FSMC_NORSRAMInitStructure );
void FSMC_NORSRAMInit(FSMC_NORSRAMInitTypeDef* FSMC_NORSRAMInitStruct)
  /* Check the parameters */
  assert_param(IS_FSMC_NORSRAM_BANK(FSMC_NORSRAMInitStruct->FSMC_Bank));
  assert_param(IS_FSMC_MUX(FSMC_NORSRAMInitStruct->FSMC_DataAddressMux));
  assert_param(IS_FSMC_MEMORY(FSMC_NORSRAMInitStruct->FSMC_MemoryType));
  assert_param(IS_FSMC_MEMORY_WIDTH(FSMC_NORSRAMInitStruct->FSMC_MemoryDataWidth));
  assert_param(IS_FSMC_BURSTMODE(FSMC_NORSRAMInitStruct->FSMC_BurstAccessMode));
  assert_param(IS_FSMC_ASYNWAIT(FSMC_NORSRAMInitStruct->FSMC_AsynchronousWait));
  assert_param(IS_FSMC_WAIT_POLARITY(FSMC_NORSRAMInitStruct->FSMC_WaitSignalPolarity));
  assert_param(IS_FSMC_WRAP_MODE(FSMC_NORSRAMInitStruct->FSMC_WrapMode));
  assert_param(IS_FSMC_WAIT_SIGNAL_ACTIVE(FSMC_NORSRAMInitStruct->FSMC_WaitSignalActive));
  assert_param(IS_FSMC_WRITE_OPERATION(FSMC_NORSRAMInitStruct->FSMC_WriteOperation));
  assert_param(IS_FSMC_WAITE_SIGNAL(FSMC_NORSRAMInitStruct->FSMC_WaitSignal));
  assert_param(IS_FSMC_EXTENDED_MODE(FSMC_NORSRAMInitStruct->FSMC_ExtendedMode));
  assert_param(IS_FSMC_WRITE_BURST(FSMC_NORSRAMInitStruct->FSMC_WriteBurst));
  assert_param(IS_FSMC_ADDRESS_SETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressSetupTime));
  assert_param(IS_FSMC_ADDRESS_HOLD_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressHoldTime));
  assert_param(IS_FSMC_DATASETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataSetupTime));
  assert_param(IS_FSMC_TURNAROUND_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_BusTurnAroundDuration));
  assert_param(IS_FSMC_CLK_DIV(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_CLKDivision));
  assert_param(IS_FSMC_DATA_LATENCY(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataLatency));
  assert_param(IS_FSMC_ACCESS_MODE(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AccessMode));
  /* Bank1 NOR/SRAM control register configuration */
  FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank] =
            (uint32_t)FSMC_NORSRAMInitStruct->FSMC_DataAddressMux |
            FSMC_NORSRAMInitStruct->FSMC_MemoryType |
            FSMC_NORSRAMInitStruct->FSMC_MemoryDataWidth |
            FSMC_NORSRAMInitStruct->FSMC_BurstAccessMode |
            FSMC_NORSRAMInitStruct->FSMC_AsynchronousWait |
            FSMC_NORSRAMInitStruct->FSMC_WaitSignalPolarity |
            FSMC_NORSRAMInitStruct->FSMC_WrapMode |
            FSMC_NORSRAMInitStruct->FSMC_WaitSignalActive |
            FSMC_NORSRAMInitStruct->FSMC_WriteOperation |
            FSMC_NORSRAMInitStruct->FSMC_WaitSignal |
            FSMC_NORSRAMInitStruct->FSMC_ExtendedMode |
            FSMC_NORSRAMInitStruct->FSMC_WriteBurst;
  if(FSMC_NORSRAMInitStruct->FSMC_MemoryType == FSMC_MemoryType_NOR)
    FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank] |= (uint32_t)BCR_FACCEN_Set;
  /* Bank1 NOR/SRAM timing register configuration */
  FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank+1] =
            (uint32_t)FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressSetupTime |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressHoldTime << 4) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataSetupTime << 8) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_BusTurnAroundDuration << 16) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_CLKDivision << 20) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataLatency << 24) |
             FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AccessMode;
  /* Bank1 NOR/SRAM timing register for write configuration, if extended mode is used */
  if(FSMC_NORSRAMInitStruct->FSMC_ExtendedMode == FSMC_ExtendedMode_Enable)
    assert_param(IS_FSMC_ADDRESS_SETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressSetupTime));
    assert_param(IS_FSMC_ADDRESS_HOLD_TIME(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressHoldTime));
    assert_param(IS_FSMC_DATASETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataSetupTime));
    assert_param(IS_FSMC_CLK_DIV(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_CLKDivision));
    assert_param(IS_FSMC_DATA_LATENCY(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataLatency));
    assert_param(IS_FSMC_ACCESS_MODE(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AccessMode));
    FSMC_Bank1E->BWTR[FSMC_NORSRAMInitStruct->FSMC_Bank] =
              (uint32_t)FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressSetupTime |
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressHoldTime << 4 )|
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataSetupTime << 8) |
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_CLKDivision << 20) |
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataLatency << 24) |
               FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AccessMode;
    FSMC_Bank1E->BWTR[FSMC_NORSRAMInitStruct->FSMC_Bank] = 0x0FFFFFFF;
在红色字体的地方出现hardfault_handler
发表于 2016-11-14 18:32:48 | 显示全部楼层
把栈空间调大一点
 楼主| 发表于 2016-11-14 19:08:27 | 显示全部楼层
栈的空间??在哪里改??
 楼主| 发表于 2016-11-15 09:38:34 | 显示全部楼层
怎么没人回复,我自己顶
GMT+8, 2024-11-23 04:02 , Processed in 0.026947 second(s), 23 queries , Gzip On.
